12-01-2008, 08:17 PM
Re: 2.2 88 t cam differences
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
dp88 - some nice things about the 2.2/2.5 turbo engine w.r.t. cams:
1. relative insensitivity to cam choice (like most mild turbo motors)
2. only two "families" of OE cam grinds - turbo and NA (incl. carb & TBI), with modest differences in cam lift & event timing between the 2
3. only one change in camshaft "style" from '81-95: in '88 the cam followers were changed from sliders to rollers; the cams are different: a roller cam cant be used with sliders and vice versa BUT the cam AND followers can be swapped (some exception -later motors didnt have oil feed adequate for slider - see DDG) ; also in '88 the cam belt and pulleys were changed from a square tooth profile to a round tooth profile (less noise), these can also be swapped +/- '88
many of us (myself included) run TBI cams in our turbo motors; gives more power UP, loses some torque LOW
so to summarize- pretty much any 88-95 cam will work fine
