Old 12-02-2008, 08:57 PM   #1
87 lebaron 2.5l broken rod?
My Ride: chrysler lebaron
just bought an 87 lebaron with a broken rod the number one rod is broken but theres no hole in the block or oil pan i still have good oil pressure and it runs .i need to know if i could get away with buying a new piston and connecting rod ? and does any body know were to get a connecting rod i can find a piston but i cant find a rod???
CWELLMAN1 is offline
Old 12-02-2008, 10:01 PM   #2
Re: 87 lebaron 2.5l broken rod?
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
take it appart first, the cylinder walls may be scored and you will need more than a piston/rod. It could just be a broken piston though.
dyno sheet
fmic install:
crazymadbastard is offline
Remortgages | Loans | Anime Episodes | Actress | Internet Advertising
Page generated in 0.30445 seconds with 13 queries
