Old 05-23-2003, 08:49 PM   #1
Talking Almost Time!
csx669
Okay almost ready to pull the motor for her rebuild. I am dropping the block off the middle of June to have the block punched .20 over. What main bearing caps should i use?
Also, I am using a front mount Spearco intercooler. Is there such thing as too big? This one is about 28" long and 3" deep.
I am going to use the +40% injectors with a larger fuel pump. Would I have any benefits to running a regulator? Or is that only good if i up my boost level?
Any 'tricks' to getting this motor out that would make it somewhat easier? What would be areasonable HP level to shoot for? Thanks everyone!
Old 05-23-2003, 09:59 PM   #2
What's wrong with your stock ones?
If nothings wrong with your stock ones the shop, if they are any good, will align bore the block and you'll be set.
ShelbyMotorspts is offline
Old 05-23-2003, 11:27 PM   #3
Re: Almost Time!
My Ride: 87 Shelby CSX #400
Engine: 2.2 turbo 2
I'm assumeing by "running a regulater" you mean an after market adjustable one or rate of rise reg. right? If your running +40% inj. you will need to control that much fuel somehow. That's usualy done with a custom computer calibration, usualy with a 3 bar MAP.
HYDCSX400 is offline
Old 05-24-2003, 12:44 PM   #4
csx669
Cool thanks. What can I expect power wise?
Credit Card | Credit Card | Project cars | Mortgage | Buy Anything On eBay
Page generated in 0.32557 seconds with 13 queries
