06-08-2003, 01:35 PM
#24
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Do you have a multimeter to test circuits with, or verify power is actually reaching the fuel pump?
Try this test: (to verify ASD operation)
Remove the distributor from the block. Leave all connections plugged in, but pull the coil wire so it grounds to the head. Now turn the ignition switch to 'on' and turn the distributor tang (bottom) by hand. When you turn it, you should hear the ASD relay click.
After doing this, you'll have to retime the engine. Make sure the distributor is inserted back into the block in the same orientation so that the ignition timing is not 180' off.
If the ASD relay works, and you are still not getting fuel, I would use a multimeter to probe the pump connector to verify it's getting power.
