Old 06-06-2003, 10:09 PM   #1
Ready to buildup an engine 2.5 T1 or 88 2.2 T2
My Ride: 87 GLHS
Engine: 89 CB 2.2
I'm starting my rebuild for my GLHS and need to know what are the good parts if any I can work with. I have 88T2 short block that was in a fire (plastic parts melted only) and an 89 T1 complete head to pan. I've been told to go with the 89 block but I like the idea of forged parts going into it. Will the 88 crank and rods go in? I believe the pistons would be different? The T2 had been rebuilt before the fire.
I'm looking to make about 400hp with this but I like to overbuild and under run it for longevity reasons.
The fun begins....
Steve St"RACE"ner
It's been fun but I'm outta here!
powermaxx is offline
Old 06-06-2003, 10:23 PM   #2
BTW
My Ride: 87 GLHS
Engine: 89 CB 2.2
The 88 T2 block was cast in late 88 and has no provision for a fuel pump. I read on Gary's page that this would make it an 89?
TIA
Steve St"RACE"ner
Old 06-09-2003, 08:04 AM   #3
Still need an answer
My Ride: 87 GLHS
Engine: 89 CB 2.2
Come on guys, someone knows this. I can get a casting number if it helps....
Any machining numbers like the MOPAR V8's have???
Steve St"RACE"ner
Old 06-09-2003, 08:55 AM   #4
Re: Still need an answer
My Ride: 1987 Shelby GLHS 189
If there is NO fuel block off plate in the 88, This would Make it a commoon block... easy to check. Compare the crank snouts... if they and the brackets surrounding them are the same.. its a common block.
The 88 would be a steel crank but the pistons are all cast in td'd ( with the exception of the TIII cars)
glhsken is offline
Old 06-09-2003, 01:07 PM   #5
Thanks Ken"thumbs up
My Ride: 87 GLHS
Engine: 89 CB 2.2
The 88 came from a fire and had no pulleys, brackets, etc... so I can't compare much. Theres a bunch of melted plastic, belts, etc.. that needs to be removed. But it sounds like a common block. I assume that I can bolt on the early T2 stuff (W pump, brackets etc...)?
I'll know more this week when I can scrap off the crud so I can take it in to be machined for the rebuild."thumbs up
Steve St"RACE"ner
Loans | Dirty Dozen Brass Band | Home Loan | Credit Cards | Debt Consolidation
Page generated in 0.39641 seconds with 13 queries
