11-06-2009, 09:54 PM
Re: Injector size?
Dragmaster B
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
All turbo cars built after around mid-year of '88 got the same 33lb injectors. They're good for about 14psi. Your car won't hit 15psi without a custom computer or some other old school tricks, it will shutdown at 14.7psi. The more boost you run after that, the bigger injectors you will need. A common setup is the FWD stage5 comp, +40 injectors, 3bar map,AFPR, and a bigger fuel pump to run 18psi on a intercooled T2 turbo car(better exhaust also).
'91 Spirit R/T(Finally got one! It runs,and has all it's paint!)
'86 Chrysler Laser XT-2.2/5spd('87 TII and 523 swap done!)
'71 Plymouth Scamp(Needs to be un-riced a little!)
'72 Plymouth Duster-440 project(Someday)
'95 Dodge Dakota-2.5/5spd(Turbo project maybe?)
'97 Dodge Dakota-3.9/5spd(r/t clone, 3rd time owned, keeps coming back!)
'06 Yamaha Roadliner S-1900cc(new toy!)
