Today, 11:34 AM
Re: Only getting 2psi of boost on 84 stock laser xe
My Ride: 1987 Dodge Lancer T1
good news is it's an easy system to narrow down, bad news is 50% of the culprits require you to pull the head.
If you haven't already;
Inspect turbo for signs of fouling, to eliminate turbo.
Inspect all hoses under pressure including vac lines to eliminate a boost leak issue.
Inspect manifold for leaks (both between manifold and head, manifold and turbo, as well as from the manifold itself) to eliminate lack of exhaust pressure.
Connect the wastegate can directly to manifold with a trusted vac line and confirm vac routing then drive to eliminate a vac line issue.
Then as someone suggested to me disconnect the wastegate actuator and wire it closed and drive "carefully" to eliminate a swingvalve issue.
If you get to the bottom of the list without finding the cause then you probably need to do a leak-down because the only thing left is blown headgasket and/or cracked head.
