Old 11-07-2009, 10:47 PM   #1
Thumbs up Good head????
My Ride: 91 gtc lebaron 2.5
Engine: 2.5 inter. t2
Do u think my head and valves still look to be in good shape?
9125lebaron is offline
Old 11-07-2009, 11:05 PM   #2
Re: Good head????
My Ride: 96 neon
Engine: 2.0L
Looks pretty good from here.
Jack's Dodge is offline
Old 11-08-2009, 08:27 PM   #3
Re: Good head????
do the valves still look good?
Old 11-14-2009, 03:49 AM   #4
Re: Good head????
My Ride: 1988 Lebaron
She looks good, just a little golded out. you ought to spray wash it and clean her up nice.
Buckracer is offline
Old 11-14-2009, 07:47 AM   #5
Re: Good head????
If you did not have a headgasket issue running a cylinder leakdown test prior to head removal would have verified any valve/valve guide/cracked head issues.
They make a "straight edge" specificaly for checking head flatness, no more than .004 variance.
I would definatly replace the valve seals while it is off the vehicle.
Jan
1990 Daytona Shelby VNT
NAJ is online now
Old 11-14-2009, 11:40 AM   #6
Re: Good head????
My Ride: 96 neon
Engine: 2.0L
Would soaking in denatured alcohol clean it up? Was just wondering would work like using gasoline.
Old 11-15-2009, 12:11 AM   #7
Re: Good head????
I think we just used brake cleaner and air when my head was off.
We did not use anything abrasive or really harsh.
When I did my 72 Duster I removed all of the valves, cleaned all deposits from the combustion chambers with a wire wheel, cleaned all the deposits from the valve stem/face with a wire wheel, cleaned the head in a safty clean tank, relapped all the valves, replaced a couple of burnt exhaust vavles and put it back together but......
That was a carburated car with a cast iron head, completly different.
I did the Duster bcause I was using a qt of oil every 200 hundred miles due to valve seal issues, after I did not lose a qt in a year.
Jan
NAJ is online now
Old 11-15-2009, 01:46 AM   #8
Re: Good head????
My Ride: 2.5 TI Spirit
Engine: 2.5 Turbo
Kerosene or diesel.
turbospirit is offline
Old 11-15-2009, 08:11 AM   #9
Re: Good head????
My Ride: '89 Daytona Shelby
You need to look at the valves out of the head to determine if they are in good shape or not. The seat angles will show valve wear and if they are good enough to reuse. If the valves are pounded out, this is were you'll need to look.
puppet is offline
Old 11-15-2009, 08:29 AM   #10
Re: Good head????
Authorized TD Vendor
My Ride: Spirit R/T
Engine: 3L V6
So what is the story behind the head being off the engine? That would help us know what issues we should be looking for and advise you on what should be done.
As a general rule of thumb, when I R&R aluminum heads, I have them milled and pressure checked. A decent machine shop can often get this done same or next day.
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Page generated in 0.19197 seconds with 10 queries
