Old 02-08-2010, 12:57 PM   #1
Cool Water running out of tail pipe, over heating
Level 2 Supporter
My Ride: 1988 Labaron
Engine: Turbo 1 2.2 liter
Feedback: (6)
I have water comming out of my tail pipe. Does this indicate a blown head gasket: Also the engine over heats.
CBMDennis is offline
Old 02-08-2010, 01:25 PM   #2
Re: Water running out of tail pipe, over heating
My Ride: 89 LeBaron conv.
Some water is normal, IE condensation. If it's a LOT of water that is a good indicator of a blown HG. Also check for bubbling in the coolant overflow tank, loss of coolant, mixing of coolant/oil where the oil will look like a chocolate milkshake. Overheating is both a cause and an effect of a blown head gasket.
Hoverfish is offline
Old 02-08-2010, 06:26 PM   #3
TD Hardcore User!
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
If you start an engine cold, and just let it idle up to operating temperature, a LOT of water can pool up in a low spot of the exhaust, such as the muffler, and when you take off, it'll literally leave a trail of water behind you. Especially in the winter.
H20 is a byproduct of gasoline combustion, and even a perfectly healthy engine can leave a trail of water when the conditions are right. I hear that the temperatures in FL have gotten down into the 40's, which is definitely cool enough for this to happen. If the head gasket is at fault, coolant consumption will be substantial and it would probably spit and sputter on startup after a 6 hour cold soak.
phantomrt is offline
Old 02-08-2010, 06:50 PM   #4
Level 2 Supporter
Feedback: (6)
I've back flushed the system several time. Even with the thermistat taken out it still overheats quickly. Any ideas
Old 02-08-2010, 07:58 PM   #5
TD Hardcore User!
Does the cooling system build pressure right away? If so, yes, your head gasket is shot and/or there is a big crack in the head or block that is causing it.
Old 02-10-2010, 01:12 AM   #6
85dodge600
My Ride: 1989 Dodge Shadow ES
I think I'll leave the current turbo in until i do build up the rest of the parts. Plus I NEED a manual trans in this thing, I'm sick of the automatic. But concerning my 85 2.2 head, I had it rebuilt when it was in my 600, New cam, re-planed, and all the goodies. But when we had the motor in the car i heard a tapping and it was coming from the top end. I didnt have the time to do all the work to diagnose it so we just swapped the extra head i had onto the motor and no more noise. So i guess I'll have to check that out sometime this week and see if I can spot something. Also since it is from the 2.2 wouldnt I need a spacer to use with the 2.5?
william123 is offline
Old 02-10-2010, 01:13 AM   #7
amazing
Old 02-10-2010, 01:13 AM   #8
fantastic
Old 02-10-2010, 10:45 AM   #9
Level 2 Supporter
Feedback: (6)
Turned out to be a blown head gasket.
Old 02-10-2010, 02:42 PM   #10
That's weird how'd my post end up being pasted in here?
85dodge600 is offline
Tags
cbmdennis
Page generated in 0.17618 seconds with 11 queries
