Turbo intake pipe: Optimal Length and Size? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
post #1 of 9 Old 04-06-2011, 02:29 PM Thread Starter
My Ride: Neons + Caravan
Engine: 2.5T
Hey gang,
Back when I was doing an N/A neon build, I remember how the intake pipe size and length could put additional torque peaks throughout the band, improving power in some areas, if not all. From what I recall (been years), the longer the pipe, the lower the peak torque was added. The bigger around the pipe, the less restrictive to preserve top end performance. I ended up doing I think a 2.5" or 3" pipe that snaked through up into the fender that was like a few feet long all together. Never did get a chance to dyno the difference, but I have seen other people who have.
Now in the turbo world, I was curious: does this phenomenon play a roll?
Currently, I have the S60 Turbonetics on my 2.5L. Being the stickler that I am, I want to try and get everything done "right". Currently, the intake goes: Turbo > 3.0L rubber pipe > Cone filter. I think the rubber pipe has to be ~12" or longer. This places the filter right next to the tranny mount.
I am about to do a new tranny cooler, which leaves a nice, large area of fresh air to enter the engine bay. I wanted to extend the intake pipe to get the filter in on that action, as it is a straight shot to do so.
I know a lot of SRT owners go straight to a full 3" pipe on their turbos. I also know most SRT owners just buy whatever is available without a thought into it. I'm cursed with that scientific/perfectionist need. The inlet is currently a 2.5" from the turbo. I was thinking of doing a stepped system, like going 2.5" pipe > 3" pipe... or even trickier, doing a "funnel" design to do the same thing.
Anybody have any insight or am I just rambling about something simpler than I want it to be?
NoDestiny is offline
post #2 of 9 Old 04-06-2011, 06:21 PM
Level 1 Supporter
twintshelby's Avatar
My Ride: 03' subaru wrx
Engine: 2.0l
Images: 3
Re: Turbo intake pipe: Optimal Length and Size?
I'd go 3inch, for intake. More air being moved, better throttle response
twintshelby is offline
post #3 of 9 Old 04-06-2011, 08:19 PM
- OFFICIAL GEARHEAD -
My Ride: Ram HFE/Omni/SL/XR7
Originally Posted by NoDestiny View Post
Hey gang,
no sry,
the presence of the turbo in the intake tract pretty much negates any potential tuning effects upstream of the turbo (inlet)
however, intake manifold tuning is still valid,
from Manifold (automotive) - Wikipedia, the free encyclopedia
"Modern intake manifolds usually employ runners, individual tubes extending to each intake port on the cylinder head which emanate from a central volume or "plenum" beneath the carburetor. The purpose of the runner is to take advantage of the Helmholtz resonance property of air."
Helmholtz resonance - Wikipedia, the free encyclopedia
detobias is offline
post #4 of 9 Old 04-07-2011, 12:28 AM Thread Starter
Engine: 2.5T
yeah, I get the intake manifold design, was just curious on pre-turbo intake to see if some of that N/A theory holds up.
post #5 of 9 Old 04-07-2011, 01:28 AM
Super Pope
The Pope's Avatar
every degree dropped on the intake pipe increase compressor efficiency and decreases exiting temps. Then adding a 3" intake tube also increases efficiency of the compressor as it isn't under such an ugly vac.
The Pope is offline
post #6 of 9 Old 04-07-2011, 09:10 PM
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
The 2.5" pipe on the turbo is the restriction. Going from smooth 2.5" to 3" netted me a 10hp gain at the track and I was still sucking in hot air till I could get my cold air box made.
Cold Air Intake
GLHNSLHT2 is offline
post #7 of 9 Old 04-14-2011, 08:57 PM Thread Starter
Engine: 2.5T
Alright, talked me into it...
Old "warm" air intake. Tucked back there.
Here is the old intake vs. new one. Going from less than a 2.5" to a full 3" aluminum.
New intake installed. Gets the fresh air directly from the front.
Took it around the block (errr, whatever, I live in the country). Stayed at 18psi pretty constantly without knock (where 17psi was usually my limit... this is without any adjustment other than the intake swap itself). I'll be doing more testing as I didn't give it a REAL good run earlier.
post #8 of 9 Old 04-15-2011, 12:32 AM
Super Pope
The Pope's Avatar
why didn't you go out to the grill?
still sucking rad air?
The Pope is offline
post #9 of 9 Old 04-15-2011, 08:40 AM Thread Starter
Engine: 2.5T
lol, should have had it sticking out of the grill a good foot. Call it "Car Ramrod!"
The end of the filter is actually only a few inches from the grill and nothing else in front of it (just relocated my tranny cooler to make this happen). Eventually, I'll build a little box around it that forced it to only pull air from the front.
Tags
intake , pipe , specifications , turbo
Human Verification
