not a fan of boost and carbs, however with a boost referenced power valve Holley and boost retard timing box you can do a lot more today with a carb than years ago.
A long time ago on Teamomni a member had side draft Webers with a turbo.
Ok
#1 it looks great
#2 I really want to see more pics, so if you have the direct link to the image, click the little globe with the chain under it then paste it in there. If you have a html code for it (ends in /img) you can just paste that right into the message box.
If you still can't figure it out you can usually just post a link to the image and a moderator will fix it for you. :thumb:
After findiing the DC valve cover the old air cleaner looked sso dated ,so I dug out this old Plenum and powder coated it to match. Ran some 2 1/2 inch cold air pipingto include the computer and finished with big ass filter . Will put up some better pics later today
Looks cool man I like the clean routing. Did you notice any performance increase with the filter out there like that? Do you have some type of filter between the ecu and your carb?
Related Threads
Turbo Dodge Forums
2.4M posts
56.1K members
Since 2000
