ShelbyNewbys MOD POWER Thread!!! help & advice wanted - Page 5 - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - General, Exhaust & Induction
Old 10-27-2012, 03:15 PM   #61
Re: ShelbyNewbys MOD POWER Thread!!! help & advice wanted
My Ride: 1987 Shelby Z
Engine: 2.2 Intercooled
soloflite is keeping the peace
Yep, that was my old 89'.. See you finally getting round to the engine upgrade. If you're back up in the Newport News area once your done, by all means, stop by, would love to check it out. I did see you not too long ago on the highway.. glad to see you enjoying it!
soloflite is offline
Old 10-27-2012, 03:42 PM   #62
Level 3 Supporter
89TonaVa's Avatar
My Ride: 89 DaytonShelby TII
Engine: 2.2 Turbo Interc
89TonaVa is keeping the peace
Yeah. They are a blast to drive. Cant wait to finish other engine. Speaking of engines. when you had car did it have the TIII turbo or the TII on it? It a TIII on it now with 3" pipe. They say theres no such thing as a garret 3" swing valve So Im assumeing its a 2.5 in.
89TonaVa is offline
Old 10-27-2012, 07:12 PM   #63
CHAMPION OF THE LOG
onerippinturbo2's Avatar
My Ride: 85 shelby charger
Engine: 2.2l sohc bored.20
1/4: 12.550
Feedback: (41)
onerippinturbo2 is keeping the peace
t/u made a 3 in swing valve that fits the garrett, maybe that's where it came from.
onerippinturbo2 is offline
Old 10-28-2012, 05:28 AM   #64
Level 3 Supporter
89TonaVa's Avatar
No its a Garret. Guess it must be a 2.5 that came with the TIII.
89TonaVa is offline
Old 10-28-2012, 10:01 AM   #65
Garrett Booster
My Ride: '91 Daytona
Engine: 2.5L TI
bamman is keeping the peace
In case Sean doesn't respond, that turbo is a T3 turbo according to Sean. That is what the previous owner told him.
I'm not too knowledgeable in turbo's but I think its whats referred to as the T3/T4 Hybrid. I do know one thing though, Sean got his neighbor to weld the 90 degree elbow on the compressor housing.
Another thing, I measured the inducer and exducer on that turbo. I think the exducer measured 60mm but the inducer measured 2mm larger than what stock would be.
bamman is offline
Old 10-28-2012, 11:37 AM   #66
Level 3 Supporter
89TonaVa's Avatar
Cool. Should be able to push 20 lb with out much problem.
89TonaVa is offline
Old 10-28-2012, 04:11 PM   #67
That was a TIII after market. I had to cut the exhaust side of the housing on it as it would point strait towards the head and couldn't get a turbo hose on it when installed, I welded the cut off part of it back on at the factory angle so factory hoses would fit. Not sure about the make of it, but was new when I installed it. I don't recall any markings on it to put a make/model to it.
Old 10-28-2012, 04:12 PM   #68
also, recall that being a 3" swing valve if not mistaken..
Old 10-29-2012, 09:21 PM   #69
Level 3 Supporter
89TonaVa's Avatar
Keep getting told Garrit did not make one. lol but sure looks like one to me.
89TonaVa is offline
Old 11-02-2012, 06:39 PM   #70
Level 3 Supporter
89TonaVa's Avatar
Just a test.video 2012 10 14 10 05 53 - YouTube
89TonaVa is offline
Old 11-11-2012, 08:42 AM   #71
Level 3 Supporter
89TonaVa's Avatar
Well time to go get some tools for rechiping my smec.!!!!!! Wish me well lol. took electronics in navy but that was a long long long long long time ago.been and electrician since then. Running circuit traces across buildings not boards.
ShelbyNewbys MOD POWER Thread!!! help & advice wanted-2012-10-22-13.04.42.jpg
89TonaVa is offline
Old 12-11-2012, 08:26 PM   #72
Level 3 Supporter
89TonaVa's Avatar
Time for an update. Started workinh on ports on my new head. just trying to get them to match my stock ports for now. And I just got duel cal chip from Shel!!!! Thanks again Shel-Game!!!!. So I put head work aside to work on smec. have removed most of the gunk from around chip. But need to make a tooth brush pick to finish off removeing it. Working long hours for now so it will be slow going for now. I made a stencil of my stock head and put it in the new one to tell where to cut and reshape portsShelbyNewbys MOD POWER Thread!!! help & advice wanted-imag0028.jpg And heres a pick of smec and chip.ShelbyNewbys MOD POWER Thread!!! help & advice wanted-imag0032.jpg
89TonaVa is offline
Old 12-12-2012, 08:50 PM   #73
Level 3 Supporter
89TonaVa's Avatar
While I was grinding on my head tonight. I was thinking maybe i should get an F1 cam for new engine. Was wondering if this would be a good idea seeing as how intake a exhaust valves are stock. And need to check with Shell to see if cals will still be good after engine swap. Not sure how diff the grind is from the stock cam. But for now I will go ahead and order poly mounts for engine.
89TonaVa is offline
Old 12-13-2012, 11:25 AM   #74
Level 3 Supporter
89TonaVa's Avatar
Well ran into a small snafoo with the Tona. Over boost but thats in a new thead. but it has shown me that I will have to beef up induction pipe connections before going to 18lb. On another note I have just ordered my poylbushing mounts. All three. pass. side front and trans.
89TonaVa is offline
Old 12-17-2012, 04:13 PM   #75
Level 3 Supporter
89TonaVa's Avatar
Well got my chip installed. But have a snag. I cant put smec back together.. Have a feeling Im gonna have to fab something.
89TonaVa is offline
