Exhaust manifold stud size?? - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - General, Exhaust & Induction
Old 01-18-2013, 12:45 PM   #1
My Ride: 1987 Shelby Charger
Engine: 2.2L T1
StaticsShelby is keeping the peace
Hey guys I have a 1987 Shelby Charger with the T1 2.2
I had an exhaust mainfold stud fall out and its pouring water all over the ground....It's the one thats closest to the drivers side....on the bottom of the manifold...Not like thats relevent...
The trouble is that I cant seem to find a bolt to fit it....I've read on the forums that its an M8-1.25 but thats not even close....it doesnt even touch the walls....just slides right on in...The bolt I found was an M8-1.25X20MM
Please guys any help would be great this is my daily driver....
StaticsShelby is offline
Old 01-18-2013, 01:13 PM   #2
Re: Exhaust manifold stud size??
Garrett Booster
My Ride: '84 shelby charger
MarkassBauer is keeping the peace
it is supposed to be an m8x1.25, the next size up would be a 5/16 or an m10 but thats weird
MarkassBauer is offline
Old 01-18-2013, 01:38 PM   #3
Engine: 2.2L T1
LOL that figures....I live in an apartment complex so I have no bolt buckets...I guess I'll have to go to the parts store with a friend of mine and buy an M10....Am I right in assuming that the "1.25" is the thread size?
Old 01-18-2013, 06:02 PM   #4
My Ride: 85 dodge glh turbo
jordensk is keeping the peace
Im no expert but water shouldnt b coming out of exhaust stud hole. U sure sum1 didnt drill the old stud out n hit a water vane n the head. I just had 2 drill 1 out of my t1 head... Very carefully
jordensk is offline
Old 01-18-2013, 06:05 PM   #5
A 1.25 is ur typical corse thread size. A fine thread is 1.0
jordensk is offline
Old 01-18-2013, 06:20 PM   #6
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
GLHNSLHT2 has really helped outGLHNSLHT2 has really helped out
The casting behind the studs is very thin. Some went all the way through on machining, some didn't. Copper RTV works wonders to keep them sealed when putting them in. You might of pulled out all the threads. If so the exhaust manifold needs to come off and you need to put an M8x1.25 heli-coil in.
GLHNSLHT2 is offline
Old 01-18-2013, 08:05 PM   #7
TD Extreme User!
Feedback: (47)
tryingbe is keeping the peace
Head will have to come off to fix this.
I'd hate to be in your shoes.
tryingbe is offline
Old 01-22-2013, 03:07 PM   #8
Engine: 2.2L T1
Thanks for the help guys but as it turns out the 20mm bolt was simply to short...A friend of mine had an M8-1.25x30mm and it went right in....aparently the holes on the mainifold are a bit larger....
Now for the next question....I'm reading all over the place that the lower 4 exhaust manifold studs will leak coolant if not sealed properly....so if they DON'T go into the water jackets why would these guys need to seal the bolts to stop the leaking?
Old 01-22-2013, 06:16 PM   #9
Legendary Driver
GLHNSLHT2's Avatar
read post #6
Old 01-22-2013, 08:34 PM   #10
Level 4 Supporter
DetroitTurbo's Avatar
My Ride: 1985 Daytona
Engine: 2.2l
DetroitTurbo is keeping the peace
mine leaks out of the second one from the drivers side if I don't use RTV/locktite
DetroitTurbo is offline
Old 01-22-2013, 09:04 PM   #11
Level 3 Supporter
jamierpm's Avatar
My Ride: 87-88-89 Daytona's
Engine: 2.5 TII 2.2
jamierpm is keeping the peace
on all my heads the lower studs are going to coolant jackets, I use pipe tread sealer and never had any problems
jamierpm is offline
Old 02-06-2013, 06:26 PM   #12
Engine: 2.2L T1
Thanks for clearing it up fellahs,, but my question was more sarcasm than not...lol...
Old 02-06-2013, 08:39 PM   #13
My Ride: 89 dodge caravan
waterbird808 is keeping the peace
I also read that it would be nice to change the exhaust studs to allen wrench bolts but don't know what size for swirl heads.
waterbird808 is offline
