Moving the turbo down the exhaust... - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - General, Exhaust & Induction
Old 02-13-2013, 09:09 AM   #1
My Ride: 87 GLH-T
Engine: 2.2 carb for now...2.5 with 20+psi coming soon!
Images: 13
Canty is keeping the peace
Why is there not STS type system for our cars? I talked to a good friend of mine and he said that the exhaust velocity at the end of equal length headers would not spool a bigger turbo until the upper RPM range. I don't understand that. Why would the velocity be different at then end of a header than it is at the end of our log manifold? I am planning on doing some mock up and try moving the turbo but he said unless I compound the turbo, my 50 trim will never spool? What do you guys think about it?
-Matt-
Canty is offline
Old 02-13-2013, 10:38 AM   #2
Re: Moving the turbo down the exhaust...
- OFFICIAL GEARHEAD -
My Ride: Dak QC/Omni/SL/XR7
Feedback: (84)
detobias is keeping our cars running
you are correct in deducing that the exhaust flow rate (mass flow) will not decrease...
EXCEPT the energy lost as heat as the gas travels will manifest itself as slower & denser flow.
using SS instead of mild steel and / or thermal coating the exhaust manifold will help hold the heat in,
keeping velocity up ...
TDers have put together 'equal length' headers..
and a converted TBI exhaust mani flows well too, superior to the 'log' ..
detobias is offline
Old 02-13-2013, 06:02 PM   #3
Legendary Driver
GLHNSLHT2's Avatar
My Ride: 85 GLHT, 87 ShelbyZ,
GLHNSLHT2 has really helped outGLHNSLHT2 has really helped out
I think your friend should go take a flying leap off a bridge.
GLHNSLHT2 is offline
Old 02-14-2013, 10:32 PM   #4
My Ride: 87 GLH-T
Images: 13
that last comment made me laugh!
Canty is offline
Old 02-14-2013, 11:38 PM   #5
Super Pope
The Pope's Avatar
Feedback: (10)
Though I agree with that state ment about the bridge I think he could have gone into more detail
First you are building more pressure on the exhaust side than the boost side. It takes longer to fill not only a ton more exhaust volume but a ton more boost volume. Small engines need all the response they can get to spool the largest turbo they can. Many of these V8 cars really don't need boost and boost done badly still makes a ton of power. Also people add them there because of fitment. It is a major PITA to put a turbo there. Oil return is another wonderful down side.
The best way to do a header is equal length and pulsed. Then run a divided turbine housing feed by the header. Each pulse is then managed to the turbine wheel the most effective way with the least amount of reversion. Basically using the best of everything.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
89 CSX 187
05 PT GT
93 Cummins
The Pope is offline
