pros and cons - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - General, Exhaust & Induction
Old 02-13-2013, 08:36 PM   #1
pros and cons
Garrett Booster
My Ride: 84 Rampage, 85 SC
Moparman1991 is keeping the peace
What are the pros and cons of using a bigger throttle body? I found one that I didnt realize I had in all of my extra parts. I believe its the 52mm?
Moparman1991 is offline
Old 02-13-2013, 08:49 PM   #2
Re: pros and cons
TD Extreme User!
Feedback: (47)
tryingbe is keeping the peace
Larger T/B is useless if you have stock 1 piece intake manifold.
tryingbe is offline
Old 02-13-2013, 09:01 PM   #3
Re: pros and cons
Garrett Booster
Why is that? even with Porting?
Old 02-13-2013, 09:23 PM   #4
Re: pros and cons
Super Pope
The Pope's Avatar
Feedback: (10)
the neck on the 1 piece is too small for the bigger 52mm TB, no difference
The neck on the 2 piece and be ported around the corner to a 52mm TB
The 58mm TB is used with a custom plenum. The 58 makes for much faster throttle and turbo response and allows a larger turbo to spool. With a ported top end and plenum on a 2.5 the car spins the tires before boost. The 52 also makes the turbos hit harder too with a completely ported top end. Much of what you want is to add a larger turbo and be able to use it, the bigger TB is part of that mod list. Actually top end HP gained at boost is questionable.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
89 CSX 187
05 PT GT
93 Cummins
The Pope is offline
Old 02-13-2013, 10:29 PM   #5
Re: pros and cons
Level 3 Supporter
jamierpm's Avatar
My Ride: 87-88-89 Daytona's
Engine: 2.5 TII 2.2
jamierpm is keeping the peace
what engine did the 58mm come on?
jamierpm is offline
Old 02-13-2013, 11:35 PM   #6
Re: pros and cons
Super Pope
The Pope's Avatar
Feedback: (10)
99 mini van, 3.8L HO
The Pope is offline
Old 02-14-2013, 05:52 PM   #7
Re: pros and cons
Garrett Booster
What if I cut the neck off? The TB I have came with an aluminum piece that bolts up to it(I can put a pic on here later). Would it be worth cutting the neck off and welding it on straight?
Old 02-14-2013, 06:01 PM   #8
Re: pros and cons
Garrett Booster
Here it is
Old 02-14-2013, 08:19 PM   #9
Re: pros and cons
Level 3 Supporter
jamierpm's Avatar
Engine: 2.5 TII 2.2
I have a 98 3.8L minivan behind my shop but I don't think it is a HO, what size tb would that be 52?? What model minivans had a 3.8 HO , caravan sport?
jamierpm is offline
Old 02-16-2013, 09:50 PM   #10
Re: pros and cons
Garrett Booster
How would it do if I cut the elbow off welded the piece on thats in the pic?
