02-18-2013, 09:00 AM
Re: using a 1 piece intake on 85 electronics, opinions?
If I were in your position, especially considering the boost levels you plan on running, I would spend my time making sure the car is setup correctly rather than trying to intercool on the budget. IE, timing belt correct, ignition timing correct, knock sensor working, ignition system in good shape, fuel pump/ filter good, vacuum setup correctly, pcv not pumping oil into the intake, ect. I've seen more td's suffer ill fates because of these items than lack of intercooler.
Yes, this has this been done before, and I feel like I remember seeing a 2 wire ais modified to work as well (all very hack imo).
It is, I'm trying steer you (and anyone reading this) from going this route  .
