exhaust manifolds: Log vs tubular - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Go Back   Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more! > Turbo Dodge Technical Chat > Engine - General, Exhaust & Induction
Old 02-26-2013, 02:22 PM   #1
Garrett Booster
My Ride: 1985 Glh-T Omni
85glhomni is keeping the peace
Anyone have real world numbers on these such as a before and after or a direct comparison as far as power? Brands VS Brands or type VS type?
85glhomni is offline
Old 02-26-2013, 11:35 PM   #2
Re: exhaust manifolds: Log vs tubular
Super Pope
The Pope's Avatar
Feedback: (10)
the fastest 8v turbo Dodge runs a ported stock manifold.
As far as flow goes I've tested a tube header with a 1.5" primary tube and it flows worse than a ported stocker. Also tested a cast log TU custom header and it really flows well, 35 CFM per exhaust port more than the other 2.
The Pope is offline
Old 02-27-2013, 05:37 AM   #3
Too many TD projects ;-)
turbot11's Avatar
My Ride: 87 CSX#193/ Daytona
Engine: 2.2 Turbo
turbot11 is keeping the peace
It's not tublar but I am running a TBI header on my Omni:
It sucks. Was a neat idea, and fun to build, but spool up takes FOREVER. It would be good if the motor was spinning at 9000 RPM all the time, but for street use it is FAR less than ideal, I will be going back to a ported log this spring.
turbot11 is offline
Old 02-27-2013, 05:55 AM   #4
TD Extreme User!
Feedback: (47)
tryingbe is keeping the peace
Are you running a 2.2 or 2.5? Did you notice any top end gain?
tryingbe is offline
Old 02-27-2013, 06:15 AM   #5
turbot11's Avatar
Engine: 2.2 Turbo
It's a common block 2.2, my goal has been to sort of duplicate a super 60 setup. The turbo is slightly bigger than a super 60 and would a little better suited to take advantage of a 2.5. However it should spin up MUCH better than it does on the 2.2. Top end is the only place that it begins to do anything. Granted I had some swingvalve issues to work out but even after they were corrected it was a dog until 4000+ RPM
turbot11 is offline
Old 02-27-2013, 06:20 AM   #6
TD Extreme User!
Feedback: (47)
My 2.2L with TBI header + TII turbo machined for T04E 50 trim and stage III turbine wheel have full boost (12psi) by 3500rpm. It does have a ported head though.
tryingbe is offline
Old 02-27-2013, 06:37 AM   #7
turbot11's Avatar
Engine: 2.2 Turbo
I have a ported head and matching manifolds too. Wish mine spun up that fast it just doesnt seem to have enough gas flow till after 4000. I'm going to go to ported log and a better SV this spring and see how that works
turbot11 is offline
Old 02-27-2013, 12:05 PM   #8
Garrett Booster
Any clearance issues on the omni with that TBI header. It looks like the turbo and wastegate actuator are sitting out a bit.(just curious). I
Old 02-27-2013, 03:32 PM   #9
TD Hardcore User!
My Ride: Daytonas
Feedback: (11)
ChargedDust is keeping the peace
Is that a .63 A/R turbine housing?
ChargedDust is offline
Old 02-27-2013, 07:08 PM   #10
turbot11's Avatar
Engine: 2.2 Turbo
Almost! .64 A/R on the hot side
turbot11 is offline
Old 02-27-2013, 07:18 PM   #11
turbot11's Avatar
Engine: 2.2 Turbo
Acutally it fits!
The pic in the above post, the wastegate is only loosely bolted onto the compressor housing with one bolt. The motor was just being test fitted into the bay when that pic was taken, lol
turbot11 is offline
