Old 03-27-2004, 11:41 PM   #1
Common block conversion
In my 86 GLh I was thinking about the possibility of going to a common block. Would I be able to use my current top end with a square tooth timing belt?
Basically, what would I have to do to make my 86 top end (with T2 blowthrough manifold) work with the common block bottom end?
beefalobilly is offline
Old 03-27-2004, 11:53 PM   #2
My Ride: 1985 Shelby Charger
Engine: 2.2 turbo II
I'd go with the round tooth. I think you'll have to anyway. I don't think a square tooth sprocket is compatible with a common block crank. Your top end will bolt right on. Another tip: You can use your L-body water pump/housing with the common block. You'll have to notch your oil pan's lip for clearance.
ShelbyGLHS592 is offline
Old 03-28-2004, 12:04 AM   #3
THanks for the reply, didn't even think about the crank not being compatible with my sprocket...
So would the main problem be the square/round tooth mixup? A round tooth cam sprocket would bolt right up wouldn't it?
Also, the oil pan from a common block is unique to the common block isn't it?
Old 03-28-2004, 03:32 AM   #4
My Ride: 91 Shadow ES
Engine: 2.5L
oil pan needs to be from common block yes, u will have to just pull ur cam gear off and swap it to a round tooth gear bolts right up... there is no way to use the square tooth gear on teh commonblock..
Radiant_Red is offline
Page generated in 0.10861 seconds with 8 queries
