Old 10-16-2005, 10:30 PM   #16
Originally Posted by Aries_Turbo
ahhhh I gotcha. yeah the plastic piece is a pos. I'll prolly do the loctite thing in the future. All i ever use helicoils on are tranny pans usually.
Brian
Glad to help bud.
Chris Faulk is offline
Old 10-16-2005, 11:22 PM   #17
My Ride: 94 shadow base coupe
Engine: 2.5 TBI
Originally Posted by supercrackerbox
Intake/exhaust threads: 8mm x 1.0
Valve cover bolt holes: 6mm x 1.0
Transmission bellhousing: 12mm x 1.5
Flywheel bolt holes: 11mm x 1.0 (kinda hard to find)
The top three sizes will do 90% of the threads on your engine.
if that's the case, then i really don't need to purchase a big assed tap and die set then? i can just go buy the tap and dies of those 3 sizes and save me some money, eh? with the exception of the intake/ex bolts being 8/1.25
what are the sizes of the reamining 10%? i'm looking to clean up some bolts and holes in the block before assembly.
bluneon is offline
Old 10-17-2005, 02:59 AM   #18
AWD alive
Originally Posted by cams1021
When using helicoils, I like to use loctite in additon to staking the coil at the bottom.. not sure of the heat capacity of loctite grades but its something to consider.
-Cameron
my personal preference is PT #272. high strength, high temp (up to 450 deg f )
I have used it on spark plug helicoils with good success.
A NOTE OF CAUTION......
I learned the hard way, dont remove any fastners on warm engines, you are rolling the dice on spining the coil out with the fastner....yeah its a long story
no I wont bore you with it...LOL
mech1nxh is offline
Old 10-17-2005, 02:23 PM   #19
Which ones specifically?
supercrackerbox is offline
Old 10-17-2005, 03:14 PM   #20
Engine: 2.5 TBI
i really don't know as i don't have the tap and die set yet.
bluneon is offline
Old 10-17-2005, 04:23 PM   #21
Off the top of my head, the only other size I can think of on the engine itself would be the 11mm x 1.5 for the headbolt holes. Everything else I think is covered by those other three, except maybe the main caps in the bottom end. You can buy a basic Metric tap and die set at Sears for around $45, and that should have everything you need.
Old 10-17-2005, 04:29 PM   #22
Engine: 2.5 TBI
so nothing is standard? everything is metric on these motors?
bluneon is offline
Old 10-17-2005, 04:31 PM   #23
Except the rod bolts, which should always be replaced instead of repaired.
Old 10-17-2005, 04:34 PM   #24
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
what he said^^^
and some of the brake fittings.
Brian
Aries_Turbo is offline
Old 10-17-2005, 07:16 PM   #25
My Ride: 1985 Shelby Charger
Engine: 2.2 Turbo
and some of the body parts... as most of our cars has seen the inside of one shop or another and fasteners were swapped out for what was 'on hand'... lol. [OT] Pisses me off when I gotta go from my 10mm wrench to a 3/8 in the SAME LINE OF BOLTS to get the air dam off... oh well, fixed that already. [/OT]
Phreakish is offline
Old 11-15-2005, 11:19 PM   #26
Engine: 2.5 TBI
what about a general grouping of standard/NPT sizes for whatever's left? like the charge temp sensor, etc...?
bluneon is offline
Mobile Phone | Budapest Car Rental | Buy Anything On eBay | MPAA | Internet Advertising
Page generated in 1.04954 seconds with 13 queries
