Old 11-11-2005, 10:26 AM   #31
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
Id get flames out the side when i shifted the k car when it had a side exit blaster with no trickery.
Brian
Aries_Turbo is offline
Old 11-11-2005, 12:00 PM   #32
Originally Posted by Mopar_Nutz
I think Russ Jerome had some vids of his Omni throwing flames. Almost made a hot dog???
Was this his omni?
The Barron is offline
Old 11-11-2005, 12:20 PM   #33
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Images: 9
i think thats the one.....thats the one from the boosted mopar vid
RPMurph is offline
Old 11-11-2005, 03:08 PM   #34
My Ride: 89 Lebaron TII convt
Engine: 2.2 turbo II
is that omni using an injection kit or something?
Beachbum3478 is offline
Old 11-11-2005, 05:56 PM   #35
My Ride: Omni
IIRC he has a second coil and a spark plug in the pipe, and runs gas
omnious is offline
Old 11-11-2005, 05:59 PM   #36
so when u say he runs gas, he is not buring unburnt fuel from the engine. he is acutally injecting gas into the pipe?
Old 11-11-2005, 09:20 PM   #37
Mopar_Nutz's Avatar
My Ride: Shelby Z's
Engine: 2.2 TII's
If I remember right it only flamed off the throttle so I would assume its' not running a direct shot of fuel to the exhaust, but maybe just cranked up fuel pressure or something. Nice little trick that alot of people on this site could use! hahaha Hell on your motor, but pretty easy to put on a good show now and then
Mopar_Nutz is offline
Old 11-11-2005, 09:55 PM   #38
My Ride: Omni
I should of stated it more clear, it is unburnt fuel on decel
omnious is offline
Old 11-12-2005, 09:44 AM   #39
I know I plan on doing it because I'll be the only one around who has it! I have NEVER seen it done around here..and its so SIMPLE. Instead of a flip switch I just want to use a pushbutton switch.. like a starter button or something..... right after I get my car RUNNING! lol.
Old 11-12-2005, 03:46 PM   #40
if i make my own, i would need a spark plug, coil, switch/button, wires, and i guess thats it. but how would i hook it up. can i just run straight off the battery or what?
Old 11-13-2005, 12:25 AM   #41
My Ride: 88' Shadow ES
Engine: 2.2L DOHC Hybrid
...but how would i hook it up...
Look at my atachments above, the first attached picture is the one i made for my car, pretty simple
Shadow92_22 is offline
Old 11-18-2005, 01:27 PM   #42
My sister has a 89 shelby daytona...probly dont wanna hear her exhasut setup, she has dual fart cans on it with flame throwers and to bo honest it sounds sick, she put the exhaust system on and gained quite a bit of boost but she also had a clogged cat, ill try and get some pictures
turboXE85 is offline
Old 11-18-2005, 02:51 PM   #43
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
With no additional fuel source, you'll just get a little flash and pop. The F&F cars used an injector spraying into the pipe with a spark plug connected to an MSD for ignition. The color effects (blue and green flames) were from chemical additives in the fuel (i.e. copper will give a green-ish flame). I've seen old-school lowriders with ACTUAL flamethrowers built in, where they used pressurized fuel and propellant, and all the engine was for was to blow the flames out of the pipe. Very impressive!
Avenger is offline
Mobile Phone | Libros más vendidos | Remortgages | Personal Loans | Credit Counseling
Page generated in 0.57973 seconds with 13 queries
