Old 11-15-2005, 08:49 PM   #1
mini exhaust size
what size is the pipe that comes off the cat and goes to the muffler ???
2fst4u is offline
Old 11-15-2005, 09:09 PM   #2
use early 80's 2.2 manifold, use 2¼ pipe. any bigger an you will loose bottom end torque. obviously remove the cat, install a free flow muffler (if rules require) about 2ft back from where the cat was, turn your pipe out the passenger side just infront of the RR wheel
allmotor is offline
Old 11-15-2005, 09:26 PM   #3
lmao no this os for my towing turbo mini, the exhaust was hacked up and i need to fix it for the stupid emissions test and i need to replace the pipe from the cat to the muffler
2fst4u is offline
Old 11-15-2005, 09:42 PM   #4
go to your local parts store and BUY a new already bent pipe. cheap and easy and WILL pass inspection.
allmotor is offline
Old 11-15-2005, 09:49 PM   #5
If my memory is good, 2.5 inch to cat, then 2.0 inch after cat all the way to the muffler and out back.
Walker part # for pipe after muffler is #47623
Secured Loans | Debt Consolidation | Credit Report | Guitar Lessons | Debt Consolidation
Page generated in 0.35023 seconds with 13 queries
