Old 12-09-2005, 05:46 PM   #16
Originally Posted by tonyz2897
Almost forgot, here's a couple links to pages that give a discription of the thermocouples based on the part#.
Clamp type thermocouples
Screw in type thermocouples
The list of thermocouples you have to choose from with the gauges was a little confusing since they are listed by part# only, but these links will let you match the part# to a discription.
While I'm thinking about it, any good advice as to what length probe would be best for a stock 8v manifold?
Thanks,
Tony
Wow, great links. The probes read from the tip, so depending on where you will be drilling, you might want a different lenght probe. The screw in style probes that are listed in your length are compression style, so that should help with any fitment issues. I believe the auto meter probes are 4".
ETA: the auto meter probes are what I am using.
OmniGuy123 is offline
Old 12-09-2005, 06:43 PM   #17
My Ride: 89 Daytona ES
Engine: 2.2L TII
Here's mine incase you still need a pic or two
diabloed is offline
Old 12-09-2005, 07:08 PM   #18
http://memimage.cardomain.net/member_images/2/web/350000-350999/350489_214_full.jpg[/IMG]
http://memimage.cardomain.net/member_images/2/web/350000-350999/350489_215_full.jpg[/IMG]
That is right were I have mine at. I would caution that one should keep the angle of the probe in mind, as it could interfere with the block.
Old 12-09-2005, 07:29 PM   #19
Engine: 2.2L TII
Cordes: i think you were the one i discussed this with when i drilled mine... mine still touches the block but not so bad as to hurt anything
diabloed is offline
Old 12-11-2005, 08:07 PM   #20
Good to hear it.
Old 12-30-2005, 01:13 PM   #21
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
I never figured out how to get the clamp around my stock manifold runner, so I just hold the probe in with safety wire. Works fine.
John B is offline
Old 01-10-2006, 09:17 PM   #22
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
The instructions to my EGT probe warned NOT to install the probe upstream of the turbocharger. I do not know why, but I did it anyway. I did it right at the collector.
I drilled and tapped to install mine, but it somehow came loose last summer, so I squeezed my hands up there again to tighten it up again. I just hope it stays tight and I don't have to keep doing this all the time. No problems otherwise.
The clamps should work fine and should last forever like that. It just looks like a cleaner installation when you drill/tap.
phantomrt is online now
Old 01-10-2006, 10:08 PM   #23
My Ride: No slicks Omni
Liability, they dont want to buy you a new turbine wheel when
the probe breaks off and chews up 320,000 RPM turbine blade
russ jerome is offline
Old 01-13-2006, 02:21 PM   #24
I would think upstream of the turbo would be the preferred position, without a doubt. Besides the response time being much slower after the turbo, it would read cooler. How much cooler is something someone else could say, but think how much work that exhaust gas has done by compressing the intake charge, and how much the exhaust gas has expanded by that time. That makes it cooler. If 100 degrees is the difference between happy pistons and melted pistons, I'd make it worthwhile by putting the probe in the right place.
Dan
lotushd is offline
Free Anime | Loans | Mobile Phones | Debt | Xbox Mod Chips
Page generated in 0.44404 seconds with 13 queries
