Old 01-20-2006, 10:27 PM   #16
Originally Posted by Will Martin
Thanks guys.
dont let it go to your head buddy
i got my new 16v top end today
shelbyplaya is offline
Old 01-20-2006, 10:47 PM   #17
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
Ha-ha, never that. I remain humble as always. So when do you think it'll be on the road? And will you still use your TBI header?
'01 Maxima SE
Will Martin is offline
Old 01-20-2006, 10:54 PM   #18
i'm gonna be useing the TBI headder on the 2.5L set up i was telling you about.
i'm hoping to have the 16v done in a cuple months.. gonna take my time on it and collect all the parts first. gonna get me a big turbo in a cuple weeks i hope!
Old 01-20-2006, 11:19 PM   #19
Sounds good! Don't abandon this one..... Got the GLH done. Just gotta fix the starter.
'01 Maxima SE
Old 01-20-2006, 11:23 PM   #20
nope, got to much into it alredy. this one will get done. i wanna find a 88 or 89 daytona shelby shell. as long as it's got a good solid body and no rust. then drop the 16v into that.
Old 01-21-2006, 03:50 AM   #21
so how did the tbi header do in flow test? Why not just dent the firewall to get more clearance?
cj011 is offline
Old 01-21-2006, 12:30 PM   #22
You have to do a search and go through all the B.S. to find the flow numbers. You know, one of those threads were people bicker and argue and no point is ever made? LOL Well if my memory is correct the TBI header flowed the best, next was T.U. header, Alabama Man header, ported stocker and then stocker. I don't have to dent the firewall because it all fits. The wastegate canister touches a little bit but not enough to hurt it. Plus, it's not an issue of what's best for me, just wanted to get my car on the road so I can start my other project.
'01 Maxima SE
Old 01-21-2006, 03:26 PM   #23
hee hee hee, the 'other' project
the red shelby should be finished today.
Old 01-21-2006, 04:01 PM   #24
My Ride: CSXT
if you were going to do it all over again would you just port a stocker, or do the TBI again?
juxsa is offline
Old 01-21-2006, 04:26 PM   #25
My Ride: No slicks Omni
I made a custom longer rod for actuator, then made
a bracket to rotate mount further ahead:
http://hometown.aol.com/russjerome/i...%20header2.jpg
Best pic I could find but it's the wastegate end of rod that's
the custom longer part. Held up so well it's even longer now
and on my Hybrid turbo/motor.
russ jerome is offline
Old 01-21-2006, 04:58 PM   #26
russ, your definatley never a let down when it comes to tech help.. and everything you make always looks soooooo damn clean
Old 01-21-2006, 05:47 PM   #27
I'd use the TBI again, but I'm not too sure it would be in an L-body!
That's about the same position mine is in. Very close to the compressor, but my rod is just slightly at a lessor angle. As long as it works.
'01 Maxima SE
Old 01-21-2006, 06:02 PM   #28
will, we dont need to know about your rod!
WoW Gold | WoW Gold | Watch Anime Online | Guitar Lessons | Online Loans
Page generated in 0.48172 seconds with 13 queries
