Old 01-20-2006, 12:09 AM   #1
question for the guys ueaing a TBI headder.
i just test fitted my turbo and obviousley the waste gate can is hitting the fire wall. what did you guys do to mod the waste gate can to fit back on?
i was thinking of useing an old T1 can.
anyone get any ideas?
shelbyplaya is offline
Old 01-20-2006, 03:22 AM   #2
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
Ray,
I didn't get a chance to take pictures of how I did it (partially because I was so frustrated afterwards) but it's pretty easy. I took a Mitsu can and cut it off the bracket. Then I just drilled the holes for the can to fit on the bracket. Next, I just angled it so it would fit and drilled a hole and screwed it on the compressor housing using a compressor housing bolt. I also had to cut my actuator rod because it was too long. It touches the firewall just a little bit, but not enough to hurt anything. Plus I have the Poly Bushings adj. bobble strut pretty tight to the engine won't rock back too much.
'01 Maxima SE
Will Martin is offline
Old 01-20-2006, 08:20 AM   #3
My Ride: 1987 Daytona ShelbyZ
Engine: 2.2 T2
that pic is scaring me . what car is that in? please tell me i won't have to run my compressor housing like that.
overboostperformance is offline
Old 01-20-2006, 10:13 AM   #4
his set up's in an omni. and thats a big turbo!
Old 01-20-2006, 11:11 AM   #5
My Ride: CSXT
how much improvement is there with a tbi head versus a stock turbo header? and also how much more difficult is it to stick mount a turbo and route all the hoses to the turbo from there? I would be using a super 60 or maybe a small t3/14 turbo. I have an 88 shadow.
juxsa is offline
Old 01-20-2006, 12:05 PM   #6
Well in an Omni your choices are very limited. I researched and researched and researched and just like everyone else that has run a TBI header in an Omni, that is basically your only choice. The compressor housing isn't touching the firewall, but it's about 3/4" away. It's a .63 compressor, 50 trim T3/T4 stage I. Believe it or not, once you get everything bolted up, changing the turbo could possibly be done without removing the engine. But I don't ever want to do this in an Omni again! LOL I should be taking it on it's maiden voyage today. :banaride: I would imagine in your Shadow you'd have a bit more room.
From my research and talking to people that've done it, there is a great improvement over a stock exhaust manifold. Obviously the more upgrades you have (ported head/engine work/exhaust/cal etc), the more you'll benefit from it.
'01 Maxima SE
Old 01-20-2006, 01:10 PM   #7
My Ride: 89 LeBaron & 99 WS-6
Engine: 2.5L turbo & 5.7 LS1
wait, that turbo is in an omni? and is that quick plumb your using? if you hear a loud POP, thats what it is
LynX853 is offline
Old 01-20-2006, 01:18 PM   #8
My Ride: CSXT
my plan is to use either the super 60 or a small hybrid. When I go to the machine shop to drop off my forged pistons I plan on asking them about mild head porting. Everything is being bolted on to a 2.5 CB. Does any one have any flow numbers with a tbi header versus a stock turbo header?
juxsa is offline
Old 01-20-2006, 01:37 PM   #9
Yes it is.
I don't know what it's called-got it from Home Depot. All I know it works. I've had it at 25psi on my S60 VNT and never had a problem. And it's rated for a higher psi than I'll be using on my turbo. And if it does go, then I'll just replace it.
'01 Maxima SE
Old 01-20-2006, 02:08 PM   #10
If you can sort through all the madness, there's a thread around here somewhere that someone did a flow test on some different exhaust manifolds and the TBI flowed the highest. And before this thread turns into madness, I personally don't care what it flows. As long as it's better than the unported stocker and does the job. Plus this is my daily driver, my real project is my SRT4 Rampage.
'01 Maxima SE
Old 01-20-2006, 04:09 PM   #11
My Ride: CSXT
I will have to do search for that thread. I would love to see some pix of your rampage project. Do you have a site with that info on it?
juxsa is offline
Old 01-20-2006, 05:34 PM   #12
http://www.cardomain.com/ride/719818/1
Unfortunately, I can't start it until I finish my GLH, which I am trying to do by today.
'01 Maxima SE
Old 01-20-2006, 06:32 PM   #13
My Ride: CSXT
dude... your carsdomain page is Awesome
juxsa is offline
Old 01-20-2006, 07:16 PM   #14
+1 ^^ that is a great site. It'll be plenty helpful when I do mine this winter.
shadow88 is offline
Old 01-20-2006, 10:14 PM   #15
Thanks guys.
'01 Maxima SE
Credit Cards | Credit Counseling | Debt Consolidation | Loans | TurboTax
