Old 01-26-2006, 12:03 AM   #1
has anyone tacked nuts to the ex. housing to aid in install/remove?
My Ride: 99 Cummins
Engine: 5.9
Images: 6
Just curious if anyones tried tack welding a nut to the exaust housing/swingvalve where the downpipe bolts to.. just to make it alot easier to remove and install exhaust/turbo?
Just wonderin.
Timmay2 is offline
Old 01-26-2006, 06:47 AM   #2
My Ride: '91 Shadow Vert
Engine: 2.5 turbo
Sounds like a good idea!
John B is offline
Old 01-26-2006, 08:12 AM   #3
My Ride: 1991 Daytona ES
Engine: 3.0 V6
Did it on my stock car 2 yrs ago and I haven't had any problems. My exhaust comes out a couple times per year so the bolts rusting in place isn't an issue for me.
crashgordon56 is offline
Old 01-26-2006, 08:56 AM   #4
Engine: 2.5 turbo
I use the nickle base hi-temp anti seize on mine and they come off just fine.
John B is offline
Old 01-26-2006, 09:25 AM   #5
Engine: 3.0 V6
Last year I purchased an aftermarket spring & bolt kit for my exhaust and the nuts had large tabs welded to them. There was no need for a wrench and it mad them easy to hold in place. I think it's a better idea than welding the nuts to the swing valve housing (just in case).
Old 01-26-2006, 09:45 AM   #6
My Ride: 1987 Sundance
^ +1 You can find "flag bolt" exhaust parts in the Help section of most auto parts stores.
"I use the nickle base hi-temp anti seize on mine and they come off just fine." this what I do and never have a problem.
guyd_15 is offline
Old 01-26-2006, 10:52 AM   #7
My Ride: 88 sundance
pn 4301250 from chrysler
jdawg is offline
Old 01-26-2006, 02:08 PM   #8
welded inconel nuts to mine.... used antiseize.... factory should have done that....when tearing a turbo dodge apart for the first time, it is obvious that the factory never used antiseize anywhere..... and certainly went cheap on bolt quality....
this idea works great!!!
RYNO
Turbofreak is offline
Advertising | Online Loans | Debt Consolidation | Power Tools | Debt Consolidation
Page generated in 0.36972 seconds with 13 queries
