08-22-2006, 02:45 PM
GTCUL8R
My Ride: 1989 LeBaron GTC
Engine: Turbo II 2.2L/135ci
Originally Posted by nemesismachine
Why not get the downpipe jet hot coated?
You're looking at between $75 and $100 to do that. I asked this question about a week ago and everybody pretty much said it wasn't worth that. There is a member on here that will do it for $70, shipping included.
As for the original question. Heat wrapping can also store moisture causing corrosion. You're better off getting a high temp coating if you feel it is worth it. Either wrapping or a high temp coating will store the heat energy in the pipe keeping out of the cabin and will help with exhaust scavenging. Also, the heat energy will be dissipated after that by the cat and the rest of the pipe, but that should only concern you to reduce cabin temperature. If that bothers you then an undercoating, heat shield, or high temp coat the entire exhaust.
My CarDomain Garage
