09-23-2006, 12:32 PM
Idea for a cheap exhaust improvement
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
Here's my idea for a cheap exhaust mod that should make it essentially wide open, but the stock pipe can be easily used for normal street driving.
My '87 Shelby Charger has a 2-1/2" pipe from the turbo back to the cat. Then it downsizes out of the cat, then downsizes again going over the axle.
With that, I got 163 WHP on 12 psi non intercooled boost, on an almost stock 1986 2.2 Turbo engine. Lightly ported head, blow through intake, '86 slider cam, and ported 2-1/2" swingvalve.
Anyhow, right in front of the cat in the 2-1/2" pipe. take a cutoff wheel and cut a rectangle out of the bottom side of the pipe. About 1-1/2" to 2" wide and 3-4 inches long.
Get another piece of 2-1/2" exhaust pipe and cut it down the middle, so you have a half circle piece of pipe about 5-6 inches long.
Get 2 muffler clamps, maybe in the 2-3/4" size.
Now when you want an open exhaust, just unclamp the 2 clamps, slide them over on the pipe, and snug them down again. Or remove them entirely. Then the half circle piece of pipe falls off, uncovering the rectangular hole you cut in the original pipe.
That should open the exhaust enough to essentially make it like an open pipe, plus you don't have to pay for an actual cutout piece, or go through the hassle of dropping the whole pipe when you want to open it up for racing.
And it's CHEAP!!!
I know, running an open downpipe is also cheap, but there times when excess noise isn't a good thing.
