Old 10-20-2006, 10:34 PM   #1
3inch clearance issues
My Ride: 89 Daytona Shelby!
Engine: Turbo II
i bought a 3 inch exhuast for my 91 spirit and put 2/3 of it in, but the piece that goes over the axle is hitting the spring, and is 1/8 inch away from my gas tank. should i go to a smaller exhaust or try to bend the one i already have? please help.
Andrew
parker87 is offline
Old 10-20-2006, 10:38 PM   #2
My Ride: 85 GLHT, 87 ShelbyZ
loosen the straps on the gas tank and slide it over a bit. Don't go smaller.
GLHNSLHT2 is offline
Old 10-20-2006, 10:44 PM   #3
Engine: Turbo II
ok thanks, i thought about that but was sure if i could.
parker87 is offline
Old 10-21-2006, 05:28 AM   #4
My Ride: '65 Polara
Engine: 2.2/ 440
Also,
try manipulating both sections of pipe at the same time. I just installed a 3" setup in my Lancer, and initially had the same issue as you do...by rotating both pieces slightly, I now have 1/2" on both sides!
lernin' is offline
Old 10-21-2006, 10:32 AM   #5
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
I had similar probs but I have a custom rear suspension so I thought it was mostly that. I moved the tank over, and bent the lip of the tank w/ a hammer also
speeduphoria is offline
Discount digital cameras | Air Jordans | Bad Credit Mortgages | Online Dating | Inkjet Printer
Page generated in 0.50756 seconds with 13 queries
