Old 11-03-2006, 07:41 PM   #1
New down pipe question
My Ride: 1986 Dodge Daytona
Engine: 2.5 TBI
Images: 2
Was there any 2.5" application from the factory on a G body or other that would work on an '86 Daytona?
86Tona is offline
Old 11-03-2006, 08:02 PM   #2
My Ride: '89 plymouth voyager
I don't think it's an issue with the downpipe, I think it's the swingvalve that is the problem. If you had a 2.5" swingvalve I think it'd go... don't quote me on that though
tkelly27 is offline
Old 11-04-2006, 09:41 AM   #3
My Ride: 89 Chrysler Daytona
Engine: 88 2.2 T1-T2 upgrade
86 had 2.25" swingvalve and downpipe, you could have a shopmake a downpipe with a transition from 2.25" - 2.5" to help you out a bit but getting a new swingvalve will help more.
88 T2 cars had a 2.25" SV with the large flange that bolts to a 2.5" exhaust.
89 T2 cars had a 2.5" swingvalve and the large 2.5" flange for 2.5" exhaust.
all other stock turbo cars with a garret turbo had a 2.25" swingvalve and the small 2.25" flange for 2.25 exhaust.
daytonajesse is offline
Old 11-04-2006, 09:20 PM   #4
Engine: 2.5 TBI
Images: 2
89 T2 was the only year with the 2.5" swing valve and large flange? Did they keep these (the size) in the later years like '90 and above? It sounds weird that they would use the larger size only in '89. What did the T3 have I wonder?
86Tona is offline
Old 11-05-2006, 06:47 PM   #5
Not sure on the T3 cars Sv size.
They only made T2 cars for 87-88-89 thats why only one year for the true 2.5" SV.
The only other 2.5 SV is on a mitsu turbo 89 and up I think, and it is not compatible with a garrett turbo
Old 11-06-2006, 09:36 AM   #6
Authorized TD Vendor
glhs727's Avatar
Feedback: (15)
The 89-up cars had a 2.5 inch downpipe. They are fairly universal. To use on a 2.25 swingvalve, all you have to do is elongate the bolt holes on the DP flange until they match the spacing on your 2.25 sv. They will bolt right up. Use a new 2.50 donut.
later,
Cindy
Your FWDperformance Team
281-288-4411 or 281-642-3878
glhs727 is offline
Old 11-06-2006, 10:49 PM   #7
Engine: 2.5 TBI
Images: 2
Thanks to all. When I go with the 2.5" down pipe I'll change the entire system. This will include the swingvalve to include a change to the 2.5" as well.
86Tona is offline
Old 07-18-2007, 11:41 PM   #8
later,
Cindy
I'm interested in your 2.5" Kit for my 86 Daytona Turbo Z and was wondering if you had any pics showing what you mean with elongating the bolt holes on the Down Pipe. Thanks!
Michael_Valentine is offline
Old 07-19-2007, 01:09 AM   #9
Feedback: (32)
tryingbe is offline
Old 07-19-2007, 07:13 AM   #10
The factory downpipe is 2.25 for the first few inches and then flares to 2.5'' down to the cat. After the cat it comes back out 2.25''. Cut the exhaust off right before the cat and bam instant 2.5'' pipe there to start with. It's not worth messing with downpipe spring/bolts and donuts plus cutting the flange. Just let the stock downpipe on take a sawzall and cut off right before the cat (cutting the cat off), and you have a perfectly good 2.5'' pipe to start with. There will be no gain for your trouble of putting a full 2.5'' downpipe on the 2.25'' swingvalve, so let the stock DP on there.
87dtna is offline
Old 07-19-2007, 10:36 AM   #11
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
Here you do it to the flange you grind away the red with a dremel or a file, here is an ultra precise 3d autocad, it took me 4 hours. Hope it helps!
dyno sheet
fmic install:
crazymadbastard is offline
Old 07-19-2007, 11:08 AM   #12
Cool, I figured this is what she meant, but wanted to be sure before I start grinding away at a $100 + piece! Are the Swing Valves easy to replace? I was told not to mess with it since I might break the bolts and cause myself a nightmare. The Turbo was rebuild about 3 Years (6000 miles) ago by the previous owner so it might have been removed during that time.
Old 07-19-2007, 11:30 AM   #13
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
You might be ok as long as the bolts weren't overtightened and antiseize was used. There is one bolt that you have to stick your ratchet with a short socket into the exhaust hole to get at it.
dyno sheet
fmic install:
Old 07-19-2007, 12:33 PM   #14
Thanks, what is the best way to remove the swing valve, from underneath or from the top? Nothing more than basic hand tools required..correct?
Old 07-19-2007, 02:48 PM   #15
So you are replacing the swingvalve too or what? If you aren't putting on a 2.5'' swingvalve than replacing the factory downpipe is a WASTE OF TIME and effort AND money. The factory downpipe is 2.5'' at the cat, and you will see NO GAIN whatsoever by all this work to put a 2.5'' downpipe on a stock 2.25'' swingvalve.
87dtna is offline
Credit Cards | Debt Consolidation | Guitar Lessons | Secured Loans | Debt Consolidation
Page generated in 0.57402 seconds with 14 queries
