Old 11-07-2006, 02:25 PM   #1
Sticking wastegate in 3" swingvalve
My Ride: 85 GLH
Engine: 2.2T
Hello all. I have an 86 glhs with the turbo removed and I just installed the turbos unleashed 3" swingvalve. The wastegate can itself is working fine, however, the (not sure what its technical name is) round cover that is actuated by the wastegate and covers the turbine bypass is sticking. I have a picture that shows what im trying to say.
My question is this. Will the wastegate actually open enough for this to happen? The wastegate at the sticking point is almost fully extended. Has anyone ever had this type of problem before?
Maybe I'm worrying too much, but I dont want to get this put back on to find out that it is sticking and I have no boost!
Thanks everyone for the help.
spymac is offline
Old 11-07-2006, 02:40 PM   #2
My Ride: 94 Ford Lightning
Engine: 351W v8
Spy,
I'd probably post this in the vendor section, or shoot TU.com an email and ask them what's up.
It sure looks funny in the picture.
Subliminal is offline
Old 11-07-2006, 02:43 PM   #3
My Ride: 85 GLH
Engine: 2.2T
Well, I wanted to see if anyone else had this problem or if the wastegate will even open to this extreme during normal operation. Also, I was thinking that under pressure the valve might not sag in order to get stuck. I will ask them if people think it might be a defect.
spymac is offline
Old 11-07-2006, 04:27 PM   #4
My Ride: 1987 Sundance
Yes, I had the problem. There is plenty of wall thickness, so I took out my die grinder and ground out metal until it swung open and closed without sticking.
I didn't know mine was sticking until it was installed . But now all is well.
Guy
guyd_15 is offline
Old 11-07-2006, 05:26 PM   #5
My Ride: 85 GLH
Engine: 2.2T
Thats a good idea, I could give that a shot!
spymac is offline
Old 11-07-2006, 05:27 PM   #6
Engine: 351W v8
I'd probably talk to chris before i went grinding on a few hundred dollars worth of metal that i just purchased...but I guess whatever floats your boat!
Old 11-07-2006, 05:36 PM   #7
My Ride: 1986 GLHS #126
Engine: stock
looks to me like the hole for the puck arm was drilled in the wrong spot, off by maybe .200"-.250"?.
Marcus86GLHS is offline
Old 11-07-2006, 08:32 PM   #8
My Ride: '89 plymouth voyager
the round thing is called the puck or the flapper, also it's called the wastegate, as that is literally the wastegate itself. Since it's on a little wiggle thing the angle can get messed up. Do talk to Chris, it's not your fault if it is sticking, and you should not have to fix it IMO. If you do want to fix it, break ot the die grinder like guyd said.
tkelly27 is offline
Old 11-07-2006, 09:24 PM   #9
My Ride: 85 GLH
Engine: 2.2T
Hey everyone, thanks for the replies and suggestions. I have a pretty good idea how I should attack this problem now. Cant wait to get this taken care of and have my shelby back on the road!
spymac is offline
Old 11-08-2006, 02:59 AM   #10
Ya Chris, looks like the puck is a little sloppy.
John O.
PUNKslip is offline
Old 11-08-2006, 12:09 PM   #11
My Ride: 88 Daytona Shelby Z
Chris, does it have to be SS wire?
I noticed this same issue with my early TU SV and a new .63 exhaust housing.
scott_s is offline
Old 11-08-2006, 03:08 PM   #12
My Ride: 85 GLH
Engine: 2.2T
Chris, thank you for the reply. I wrapped some SS line and also did a bit of grinding on the wastegate hole and It looks like it will work just fine now.
spymac is offline
Old 11-08-2006, 04:25 PM   #13
My Ride: 1986 GLHS #065
Engine: 535hpAluminumLongRod
1/4: 11.921
Images: 19
^Now thats service with a smile
SUPER60omni is offline
Old 11-08-2006, 06:56 PM   #14
My thanks as well on the info Chris.
scott_s is offline
Old 11-09-2006, 06:47 PM   #15
Yeah, my new 3" SV already has that part ground down.
darkredturbo is offline
eBay | Loans | Remortgages | Bad Credit Loan | Credit Cards
Page generated in 0.61426 seconds with 13 queries
