Old 02-20-2007, 03:17 PM   #16
My Ride: 85 Daytona TurboZ
Engine: 2.2L T2 Modded
how close to the studs did you go? if its too thin that would make a crack point wouldn't it?
Xplizit is offline
Old 02-20-2007, 03:59 PM   #17
NORCAL
86trbolancer's Avatar
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
Feedback: (7)
Images: 32
I don't have a measurement. But with the studs bottomed out in there holes it acts as one piece of metal in a way.
I did take a micrometer and was able to measure the outside edges of #'s 1 and 4 and there was about .030 inches in difference. #1 being the small edge(bigger port than #4). But i havn't installed this on my car yet so who knows how good it will be or if it will hold up.
86trbolancer is offline
Old 02-25-2007, 05:05 AM   #18
well i got my exhaust manifold ported today, went well. Will post pics when i get to them. Head is next then intake manifold for 52mm TB . i think i will just take it easy on the head side.
i love air die grinders with carbide bits
Xplizit is offline
Old 03-20-2007, 11:56 PM   #19
Head porting done. It went well and the head goes much faster than the manifold.
Im also getting a valve grind done and new seals and guides installed.
Ill have pics when i get it back from machine shop.
Xplizit is offline
Old 03-22-2007, 07:30 PM   #20
My Ride: 1993 Daytona
Engine: 2.5L MPI N/A
Images: 1
PLEASE post pics
Especially on the valve work. Congrats on a hopeful success so far.
ZoskalonMPI is offline
Old 03-24-2007, 04:17 PM   #21
My Ride: 88 Shadow
Feedback: (7)
Hey guys, I use carbide bits to port my manifolds, then a sanding drum on a dremel smoothes off any dimples the bits leave.
But, I'm new to head porting and want to port mine. Everytime I've gone to do aluminum my bits always just clog up. Any advice, need different bits? Are there bits just to do aluminum?
moparzrule is offline
Old 03-24-2007, 08:22 PM   #22
My Ride: '89 plymouth voyager
Haha, carbide FTW!
If they get clogged with the gummy aluminum, put some oil on them every so often. It sprays all over the place, but it kept my bits clean.
Pictures!
tkelly27 is offline
Old 03-25-2007, 11:09 AM   #23
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
Originally Posted by tkelly27
Haha, carbide FTW!
Pictures!
I use wd40 spray to keep the "tootsie rolls" from gumming up.
dyno sheet
fmic install:
crazymadbastard is offline
Old 03-25-2007, 11:27 AM   #24
itx
Would there be any point in me porting my 782 head if I'm running the little mitsu turbo or will it just lead to overboost issues?
itx is offline
Old 03-26-2007, 09:58 PM   #25
My Ride: '91 Spirit R/T
Engine: 2.2 TIII
With a fairly well ported head, you'll make more power at 10# of boost with your Mitsu than you previously made at 15#. It absolutely makes sense to open up the biggest restriction in your entire engine.
Mike
mpgmike is offline
Old 04-04-2007, 03:45 AM   #26
Mike
+1
also, you'll be looking for a new turbo after you've reached the limits of the mitsu : D
If you're concerned about overboost, go ahead and turn the die grinder on your mitsu while you have it all apart.
tkelly27 is offline
Mobile Phones | Loan | Free Advertising | Guitar Lessons | Debt Help
Page generated in 0.46798 seconds with 13 queries
