Old 03-24-2007, 04:37 PM   #1
Which exhaust for my baron
My Ride: 93 LeBaron sedan
I want to get a 3" mandrel ss exhaust system for my lebaron sedan, which one am i supposte order?
Boogieman142 is offline
Old 03-24-2007, 11:27 PM   #2
My Ride: '02 WRX
Engine: 2.0L
Feedback: (14)
here's a start ...
http://www.fwdperformance.com/Store/...2&ProductID=80
then just piece the rest together in the exhaust section !!!
if u do get it let me know how it is, ive been eye'n that out for my car !!!
hope that helps,
- Dave
D1A5J is offline
Old 03-25-2007, 09:10 AM   #3
thats what i was looking at, i just need to know which one for the sedan, they all say 2-door.
Old 03-25-2007, 10:57 AM   #4
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
I bought the spirit 3 inch/stainless, fits good with some banging and trimming and you also have to figure the hangers. This is a stainless kit I bought years ago and just installed it a few months back. Definately not a bolt on, I wold recomend having it installed by a shop. Maybe things changed with the kit from a few years back. No complaints here since it was the only kit like it back then. Just got the 3 in swing valve and down pipe, should have it buttoned up in a bit.
Seems like I always find a reason to keep my car under the knife.
dyno sheet
fmic install:
crazymadbastard is offline
Old 03-26-2007, 09:44 AM   #5
Authorized TD Vendor
glhs727's Avatar
Feedback: (15)
If you have a 4 door lebaron, then use the shadow/daytona kits. If you have a 2-door lebaron, use the spirit/lebaron kits. All of the above take the same downpipes, mufflers and cats.
later,
Cindy
Your FWDperformance Team
281-288-4411 or 281-642-3878
glhs727 is offline
Old 03-29-2007, 06:10 PM   #6
thanks, so it is all just a bolt in and go. all hangers etc... in the right spot?
Old 04-07-2007, 01:04 PM   #7
i was looking at a daytona exhaust and it has the cat under the pass. compartment right about where my resonator is my cat is up in the "tunnel" where the flex is. so would the daytona one still be the same?
Old 04-07-2007, 01:30 PM   #8
also it is a 93 lebaron le A-body if that matters any.
Old 04-14-2007, 10:26 AM   #9
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
mine had no hangers, just 3" stainless mandrel pipe sections pre bent, had to trim some, but I have new custom rear suspension on my Spirit and not sure if that was the issue or not
speeduphoria is offline
Old 04-14-2007, 02:05 PM   #10
i would think the 4 door lebaron would be either an A body or a K body and would use the A body exhaust....hmmmm
capev86 is offline
Old 04-23-2007, 05:55 PM   #11
ok, so i still am not sure on this. anyone have a 4 dr baron that has put one on?
Old 04-26-2007, 06:36 PM   #12
so, nobody has put one on a 4 dr. baron
Old 04-26-2007, 06:42 PM   #13
glhs727's Avatar
Feedback: (15)
The 4 door lebron is considered an H-body and uses the same exhaust as the daytona and shadow. I had the FWD 2.5 inch kit on my 87 shelby lancer and had no problem installing it.
Later,
Cindy
glhs727 is offline
Old 04-26-2007, 06:44 PM   #14
glhs727's Avatar
Feedback: (15)
The 93 2 door lebaron should be a J-body not an A-body. The spirit and acclaims are A-bodies. But the do use the same exhaust kits. I don't rell seeing a 93 4-door lebaron before. Got some pictures?
later,
Cindy
glhs727 is offline
Old 04-26-2007, 07:35 PM   #15
I thought the 4 dr. version was the same as a spirit/acclaim. I just realized that i only have a handful of pics of the car intact, most of them were after the wreck with me fixing it, after it got fixed i haven't taken any pics of it so this is all i have.
MPAA | Mortgage | Bad Credit Loans | Problem Mortgage | Debt Consolidation
Page generated in 0.46441 seconds with 13 queries
