no im not disputing... i was asking to learn! thanks!
but i did go check some things...
-my base ig. timing is @ 0* and has been sence the engine was built. like i said first i had to check that i wasnt forsure.
but Ondonit, y you say that? im looking for relitive information, not someone who want to just put their $.02 in w/out giveing any info to help. as for what i said. if you look up "intercooler" on
Reference.com you see that without the long words i said the exact same thing! here ill cut and paste.
"An intercooler, or charge air cooler, is a device used on turbocharged and supercharged internal combustion engines to improve their volumetric efficiency by increasing the amount of charge in the engine and lowering charge air temperature, thereby increasing power and reliability. It is also known as a charge air cooler"
now to the next part which i actually asked why this was b/c i want to know.. aka learn!
"It is also known as a charge air cooler, especially on larger engines that may otherwise easily self-destruct with high intake-air temperatures. "
so if someone would please be kind enough to give me some information w/out being a smart a**, i would GREATLY appreciate it.
sorry to the ones that are helping! its just aggaivating when someone is looking for help and gets a pointless post as that.
so please again. why will not running an ic at this boost level harm my enigne? cause knock due to the high air charge temp?
-James
