07-29-2007, 12:17 PM
GTC Muffler replacement
My Ride: 1987 Shelby GLHS
Hi All,
I have an 89 GTC TII convert. The muffler is bad. I noticed factory ones have 2 tips coming out the back and the after market ones I see have one. I have the stock exhaust system at this time. Does anyone know if theres a good aftermarket muffler that's just like the original? I'm also talking length. The car came with a replacement on it that never fit right. I found a factory one at a bone yard that fit much better and liked the look out the back more. Well that was a $3.00 temperary one that quieted the car down for the last couple months, but is getting louder. Anything out there?
As it is, I'm going to be putting a 2.5 stainless system on in the future. but in no position to do that now.
Thanks
07-29-2007, 10:57 PM
My Ride: Chrysler LeBaron Co
Engine: 2.5 I4
Hi,
I have the same car almost exactly. What I did was get the replacement parts fronm Advance Auto and put them on myself. This left the pipes sticking out to far in the rear so I took it to a muffler shop and had them weld in the muffler further up under the passenger seat and the put a new piece in at the rear to fit the resonator to the rear bumper. It is just a walker glss pack but as I remember the outlet is smaller than the inlet so I had them turn it around. It sounds pretty good but it did cost a little money getting it done.
07-30-2007, 08:07 AM
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
I bought an exhaust system for my Lebaron from Checker auto parts, only because I had a 25% off coupon. I get there, and the exhaust parts are SPECIAL ORDER ONLY! Well, the coupon doesn't work for special order. There is no fricken reason for this to be special order since they're pretty darn common yet.
I wait a few days, go there and pick it up, and the pipe is super small, crush bent,and just the cheapest, cheesiest piece of ship metal you can find. This is the stuff that lasts 2-3 summers before its rusted through. I tell them that it is too small and is supposed to be bigger to meet OE standards. Nope, cannot return it because it is special order. I am stuck with it. Still have it in the garage, waiting to be installed on a POS I buy for resale that needs some type of exhaust..
The only item of quality was the muffler--the only part that wasn't special order only, and it had the dual tip outlet. Only one of them works since one is a fake, but looks and fits well, and from the sound of it, seems to flow pretty well for a stock engine.
CHECKER SUCKS!!!!!!!!!!!!!!!!!!!!!!!!!! Not just because of this one incident either. An auto parts store that sells cheap minibikes and go-karts. hmmmm.
07-30-2007, 06:50 PM
Yeah, I only buy my auto parts at stores that sell good minibikes!
I put an exhaust on my Mom's Sha"Doh!" a couple years ago. The other day, I had to replace her MAP. When we started the car to test it. it was loud. My Mom said put the other one back on. (She's no mechanic) I told her it was the exhaust. I looked under the car and the pipe had rusted the first inch off and was hanging. That's absolutely ridiculus. The last car I put exhaust on of my own was an 83 2.2 Charger my ex and I owned. That was like 15 1/2 years ago. It's so nice the turbo cars have stainless systems.
Paul, why did you have to change the plumbing? Was it just because the muffler was bad? Is one of the tips on my GTC a dummy?
07-30-2007, 07:30 PM
Check Walker Exhaust Solutions From The Industry Leader to see if you can locate what you are looking for.
07-30-2007, 07:42 PM
This is from AP Exhaust,read the description of the muffler,dual tips.
There are illustrations on the web page.AP is Quality Exhaust,my Grandfather sold AP when he had his Auto Parts store in the 60's.
1989 LeBaron GTS, 2.2L EFI Turbo II Intercooled, 2.5L EFI Turbo I Engine (135, 153); with Catalytic Converter
(3373)
Application Footnotes:
1 • Original Equipment system was a welded assembly. It is recommended that all parts noted [1] should be replaced.
72 • Optional muffler.
142 • O.E. muffler has dual spouts that angle toward corner of vehicle. Replacement muffler has dual spouts that exit straight.
931 • This unit was designed to fit many applications. Measurement of the old unit and cutting of new unit is required.
Application Parts:
Part Number Part Details Buyer's Guide Description Layout Details
9248 Gasket Manifold To Front Pipe
4678 Man. Fstnr. Kit Front of Front Pipe Parts Kit
NA Front Pipe
M212 U - Clamp - 2-1/2" Front Pipe To Converter
642434 Converter - Direct Fit Direct fit converter (exc. GTS) (exc. GTS)
602206 Converter - Universal UNIVERSAL CONVERTER (Optional) (including GTS models) (including GTS models)
651110 Chrysler PIPE KIT (exc. GTS) (exc. GTS)
8581 Bracket Center & Rear of Converter
M178 U - Clamp - 1-7/8" Converter To Rear Pipe
34771 Tailpipe Rear Pipe; Original Equipment system was a welded assembly. It is recommended that all noted parts [1] to be replaced.
M178 U - Clamp - 1-7/8" Rear Pipe To Muffler
3270 Challenge Muffler Muffler; O.E. muffler has dual spouts that angle toward corner of vehicle. Replacement muffler has dual spouts that exit straight.; Original Equipment system was a welded assembly. It is recommended that all noted parts [1] to be replaced.
6581 MSL Maximum Muffler (Universal) (Optional) for Muffler (3270)
3475 Challenge Muffler Muffler; O.E. muffler has dual spouts that angle toward corner of vehicle. Replacement muffler has dual spouts that exit straight.; Original Equipment system was a welded assembly. It is recommended that all noted parts [1] to be replaced.; Optional muffler.
6581 MSL Maximum Muffler (Universal) (Optional) for Muffler (3475)
8195 Bracket Rear of Muffler
4975 Man. Fstnr. Kit Rear of Muffler; Bolt
08-01-2007, 08:10 PM
I think my GTC has, for the most part, original exhaust on it. When I bought the car 6 years ago, it had a muffler on it that wasn't quite installed right. It hung down much farther than it should have. It looked dumb that way, but it had a functional Y-pipe for the dual outlet. Comparatively, this one was VERY restrictive. I'd go full throttle under an overpass and the hiss noise was ear piercing. The muffler itself rusted out and the pipe part of it broke off in St. Paul. Note that this car has been winter stored for the four years prior to this thing rusting through. One of those summers saw MAYBE 4 instances of rain... seriously.
Knowing that the rest of the exhaust has some age to it, I figured I'd replace the whole thing since its actually easier that way. After I got the replacement pipe, I determined from experience that this old pipe would outlast the new stuff. So, I just slapped the muffler on, and away I went and it purrs like a kitten.
I had the same problem with my Daytona. The previous owner put an exhaust system on it shortly before I bought it. It rusted through. I installed a complete system on it (I was ~17 years old at the time) and that exhaust system saw MAYBE one winter and the car was not driven much up until the turbo engine went in about 2-3 years ago when I had to go with a substancially larger exhaust system. I still have that exhaust pipe up in my garage rafters, and its not in very good shape at all.
The aluminized pipe from FWDPerformance is twice the quality, bigger in size, and very comparatively priced. Oh, and twice the size LOL.
That 2nd outlet on your muffler may or may not be a fake. It may as well be a fake regardless because it is just a Y-pipe. You can tell if exhaust flows through it by checking for exhaust soot in them.
08-09-2007, 10:25 AM
My Ride: 89 lebaron cvtbl gtc
Engine: 2.2L turbo 2
gts and gtc are different
