08-09-2007, 01:43 PM
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
my exh mani side of the flange was warped bad, possibly due to overtightening the exh mani to turbo nuts; it was leaking like a sieve
took 30 minutes on a big belt/disc sander to get that sucker flat; then a bit of axle grease for reassembly (as erik mentions) = no leaks
if you have that problem, then no amount of grease will seal that puppy; maybe take some feeler gauges and see if they slide into the crack, find out how big it is
sorry but you may have to pull the exh mani to get it right ; oh well - good time to replace with ported and coated unit
heres what mine looked like after porting, coating, and sanding the flange flat:
