Old 08-14-2007, 11:13 AM   #1
2.2L vs 2.5L manifolds
My Ride: 85 Turbo Z, TII
Would there be any difference/compatibility issues between a 86 T1 turbo manifold and a later 2.5L turbo manifold?
Thanks,
Pete
cm961 is offline
Old 08-14-2007, 02:06 PM   #2
My Ride: '89 plymouth voyager
Just that little notch for the blow through mani.
tkelly27 is offline
Old 08-15-2007, 09:31 PM   #3
My Ride: '85 Dodge 600 Ragtop
Engine: 2.2 T1
Check The Dodge Garage for details. They have a nice drawing. Bill
Dodgeboy77 is offline
Old 08-15-2007, 10:21 PM   #4
I have a 93 2.5 exhaust manifold on an 89 2.2 common block and the only thing I have noticed is the tube going from the exhaust manifold to the bottom of the intake manifold has to be reconfigured, as the 2.2 CB intake manifold is about an inch narrower than the 2.5 intake manifold when measuring from the mating surface to the outer edge of the manifold.
Blessings, Sasky
BareFoot Soul - A Christian Rock Band
Sasky is offline
Old 08-16-2007, 01:34 PM   #5
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
early (2.2 log) and late (2.2 or 2.5 blow-thru) *turbo* exh manis are identical except the aforementioned notch was added to clear the 1- or 2-piece intake manis
hence, you can use a late exh mani on a log - no problem
but, to use an early exh mani on a blow-thru you have to grind the clearance notch
10-15 min with a good 4" angle grinder...
(I think sasky is talking NA exh manis)
detobias is offline
Old 08-16-2007, 09:39 PM   #6
Sorry I forgot to mention that I am using all normally aspirated parts. Hopefully the "892 Shakota" can be turbofied at some point... Also, I mistyped the year as it was a 92 exhaust, instead of a 93.
Blessings, Sasky
Sasky is offline
Xbox Mod Chip | McDonalds | Credit Card Shop | Link Directory | Mortgage
Page generated in 0.59657 seconds with 13 queries
