Old 11-18-2007, 11:32 AM   #1
What is a Complete 3" Exhaust ?
My Ride: 86't1 5sp
Engine: 2.2t1/swap 2.5 in t2
I have a 86 Daytona 520 with a 84' G head and a 88 Turbo Roller.
I called Cindy told her I have a daily driver and all the TII parts to up-grade to a 87' TII .
This is what she sold me;
Magnecor Wires
ECU 86/87 Stage 3 GLHS Cal
Misc part 50 (FWD 92-0769) qty. 2 ( i believe it's wirring for the TB)
Charge Air Pigtail
Charge Air Sensor
804 Injectors
Autolite 63
MSD Blaster 2
She never said anything about exhaust,and I'm confused about the 3" swingvalve.
I guess it's only 2-1\2" i.d.....?
Explain this, and what do I really need for my Exhaust System with these up-grades.
I bought the 3" Catco converter,and a 3" manderal "U" Bend, for running a 3" Side Exhaust, but I want the whole Package(3" SV- ' guess it's a actual 3" measurment', 3" DP.
prostreetdayton is offline
Old 11-18-2007, 02:36 PM   #2
Re: What is a Complete 3" Exhaust ?
Feedback: (32)
3 inch swingvalve is only offer by Turbos Unleashed |:..:| Shelby Dodge & Chrysler turbos, intercoolers, headers, parts and accessories.
Stock, your turbo would have a 2 1/4 inch swingvalve.
tryingbe is offline
Old 11-18-2007, 08:58 PM   #3
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Isnt this a 3 inch swingvalve?
FWDPerformance.com
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 11-18-2007, 09:02 PM   #4
Feedback: (7)
Images: 1
Magnecor Wires
Charge Air Pigtail
Charge Air Sensor
804 Injectors
Autolite 63
MSD Blaster 2
Probably she didn't mention it because you don't need to change the exhaust to convert to TII. For those upgrades you don't NEED to change anything on the exhaust. Unless you are planning on removing the head, you won't be changing SVs. Also, you need at least a 2 1/2" SV to run a 3" DP. Good luck with the project.
xdig is offline
Old 11-19-2007, 07:56 AM   #5
Feedback: (32)
FWDPerformance.com
You should really read the description of the product before you post.
Universal swingvalve for use on all t3 (non Chrysler) style turbos.
The part you posted will not work with ANY stock turbine housing off Chrysler/Dodge cars. Like I said, TU is the only place that have 3 inch swingvalve work with our car. Yes, there couple other 3 inch swingvalves out there, but not for our stock turbine housing.
tryingbe is offline
Old 11-19-2007, 09:04 PM   #6
My Ride: 86't1 5sp
guess i didn't understand the swingvalve and how it fits into the exhaust system.
so with the mods............. will a 3" system still be worth doing?
Old 11-19-2007, 09:07 PM   #7
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
FWIW, the 3 in swingvalve is worth a bucket of torque on a stock t2 garrett. If you have the extra $$ it is a nice piece to get. Should hold resale value too down the road if your plans change and you go for a crazy turbo.
I practice what I preach:
crazymadbastard is offline
Old 11-19-2007, 10:41 PM   #8
mopar2ya's Avatar
Engine: 2.2 TIII
Well, seeing as he didnt specify what turbo he was running, he very well could have used that swing valve. So I guess your smugness was a bit uncalled for.
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 11-28-2007, 05:44 AM   #9
My Ride: 86't1 5sp
FWD and TU both list a 2.5" Swingvalve..........I don't see a 3"
Work to late to give a call, what am I missing???
Old 11-28-2007, 05:02 PM   #10
My Ride: 88 Daytona Shelby Z
Engine: 2.2 Turbo II
Both sell a Turbonetics 2.5" SV which will fit a 3" DP.
camarobutcher is offline
Old 11-28-2007, 10:13 PM   #11
Smoking Rice in a Minivan
86LaserXE-XT's Avatar
My Ride: 89Turbo Caravan
Engine: 2.5 Turbo 1
This might be what your looking for. TU 3" downpipe with option to add 3" SV
86LaserXE-XT is offline
Old 12-24-2007, 09:05 PM   #12
My Ride: 86't1 5sp
Here are some pics of my exhaust now......I pulled the 2.2 and will be getting a 2.5 ready to go in and get the pipes all up to 3"
I have a EGT probe in the pipe but I'll need to move it to the ex. manifold, but where???
.........more later
File Type: jpe EGT Probe, moving to ex. manifold..but where.JPE (28.4 KB, 139 views)
Last edited by prostreetdayton : 12-24-2007 at 09:10 PM. Reason: need to add more info
Old 12-24-2007, 10:56 PM   #13
Hello! I have a '84 Lebaron Convertible that was TBI, converted to a Mexican Phantom(Lebaron) '90 TII, with Mitsu Turbo, does it have a 2.5" SV or 2 1/4"? I am very interested to get a 3" downpipe, and all the way to the back 3", or some nice behind the door. Does the 3" downpipe fit? even if the SV is 2.5"? I am a little confused thanks!
BTW I have searched everywhere for the Weight of my car, again, an '84 Lebaron Convertible, because everyone is telling me that because it is convertible it will be less heavy than any other so it will be FAST!
gerbot_3000 is offline
Old 12-24-2007, 11:17 PM   #14
Engine: 2.5 Turbo 1
you'll get alot of dispute over what your vertible baron weighs.
best way is just to scale it.
yes your mitsu has a 2.5" SV and you can easily throw the 3" on with an adaptor and weld it up and be good to go, although I've heard of bad Boost creep issues with the 3" SV.
Old 12-24-2007, 11:25 PM   #15
The Pope's Avatar
ATP makes a Dodge turbine 3" band clamp SV. The problem with turbo exhaust is that anything thin and welded isn't for the street, all headers melt and give on the street. Then at that point if your racing I would get the FWD tri Y header with the ATP SV. I beat my car on the street, so TU 3" SV and cast header.
The TU 3" donut is NOT for use on the 2.5" SV. They are not cut at the right angle and get destroyed and twisted in the 2.5" SV. I have an origanal Rick D donut for the 2.5" SV, fits perfect and is completely different angle than the TU donut. Most don't notice at first, the TU donut crushes down into the 2.5" SV and doesn't leak at first. So people are making them work but one of the vendors needs to make us a 3" donut for 2.5" SVs like Rick did.
The Pope is offline
