Old 11-21-2007, 12:22 PM   #1
Exhaust manifold interchange
My Ride: 1991 Shelby Daytona
Engine: 2.5L T2
How interchangable are the exhaust manifolds from like the suck through to the blow through?
91shelby is offline
Old 11-21-2007, 12:31 PM   #2
Re: Exhaust manifold interchange
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
You would have to do some grinding to on the turbo mounting flange to clear the intake runner, thats it.
You can use the manifold on your 91 with no mods to swap over to a garrett.
dyno sheet
fmic install:
crazymadbastard is offline
Old 11-29-2007, 01:01 PM   #3
My Ride: OMNI/ShelDak/TSi/SL
Engine: 2.2 'GLHS style' TII
Feedback: (36)
crazy is correct altho brief in his desription
from allpar.com
"Turbo manifolds from log intake motors may need to be notched to clear the intake runner if using a late model T1-T2 intake."
the early-TI and late-TI/TII exhaust manifolds are *almost* exactly* the same, with the primary difference being that the later exh mani's had a clearance notch in the turbo mounting flange which was added to clear the "new" 1-piece and 2-piece intake manifolds
there is a corresponding notch in the turbine housings of the turbo as well
10-15 minutes with a 4" angle grinder or good bench mounted grinder and you can remove the offending material from both the exh mani and the turbo turb. housing
check out this link
Turbo I to Turbo II
and specifically
detobias is offline
Old 12-27-2007, 12:10 AM   #4
sweetg, i picked up a t1 head assy with manifold and turbo and wanted to port it/get it coated. my question about differences is answered without asking. thanks TD!
stormy69 is offline
Myspace Layouts | Loans | Debt Consolidation | Free Advertising | Free Ringtones
Page generated in 0.67376 seconds with 13 queries
