02-05-2008, 06:55 PM
PLZ post your egt's for me.......
NORCAL
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
So i'm just starting to look into making my custom header......But i'm not sure if i wanna go all out and use Inconel 625 tubing just to be sure.....or if 321 stainless steel is enough.
Just need to get a good idea of where my temps are gunna be....
Please post with all major mods listed.
Thanks
02-05-2008, 09:20 PM
Re: PLZ post your egt's for me.......
87 TII. stock Mahle's, head, intake, exhaust manifold, and turbo.
MP stage 2 LM, +20's, big NPR, 3" exhaust (swingvalve - back), 20# boost.
1650 - EGT according to my Stewart Warner. That is with only a Dawes narrow band thingy to monitor AFR. It blinks between green and yellow.
...for what it is worth.
- Bill
02-05-2008, 11:50 PM
My Ride: 1987 Daytona ShelbyZ
Engine: 2.2 T2
87 daytona
g head
s60 turbo
tbi header
FWD stage 5 cal 19psi
+40's
Gary D fuel rail
volvo smal i/c
1450-1500
wanted to double check timing but turbo let go before i was able to
1650 is about the highest you should see out of the engine
Norm
02-07-2008, 07:30 PM
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
on my van, (stage 5 cal, +40 injectors, AFPR, twin fuel pumps, alcohol, HX-35, EGT probe in runner 4) under regular driving i see anything between 1100* and 1300-1400* driving up a hill under about 5psi, and with my alcohol, i have run 32psi at full throttle for about a 1/4 mile and only hit 1450-1500* on pump gas (but im POURING in the alcohol @ about 1 litre every 30 seconds)
02-11-2008, 01:01 PM
NORCAL
Engine: T2'd 2.2L
Cool...this is helping, thanks you guys. I going to be running forged .040 over venolias which i got in the mail the other day. Along with big valves(thanks again FWDP) in a 782 swirl head thats getting ported to hell and back...i'm not sure where i'm even going to have my hole tapped for the egt gauge in the custom header. I think i'm going to go with a design that kinda looks like horns on a ram so that 1-4 and 2-3 will be equal lengths and center the turbo behind the engine...
02-12-2008, 06:53 PM
My Ride: 1992 Dodge Daytona
Engine: 2.5l I-4 super 60
I'm sure you know, but EGT probe placement is a HUGE determining factor. If you mount two EGT probes in series, you can get some very interesting readings from each one that responds differently to air/fuel ratio.
Mine, with a stock calibration at cruise and closed loop, will run 1550 degrees on the interestate--about 3000 RPM. And I've done that for many thousands of miles. This particular engine has high quality valves in it, but the rest of the engine doesn't have many modifications that will result in substantial air/fuel ratio differences, so it is safe to assume a stock engine will have very similar EGTs.
02-14-2008, 05:51 PM
NORCAL
Engine: T2'd 2.2L
hummmm.....that sounds like a really good idea. Guess i'll have to pick up a 2nd egt gauge. I'm thinking 1 of them halfway between the head and turbo on the #4 cyl header tube. Since #4 already has coolant issues i would think that cyl would run hottest. and one right before the turbo where all 4 tubes collect into 1. Any other ideas?????
02-15-2008, 11:31 AM
DO NOT put it in runner 1, runner 3 would be OK, but runner 4 is best. like you say, runner 4 does have cooling issues already, making it the best runner to go it. if you put it in runner 1 so it "dosnt get skewed by others" your looking for trouble. if anything, you want it to be reading from the hottest place in the manifold so your safe. runner 1 might be reading a perfect
1500*and youll feel all good inside, wile runner 4 might be hitting 1600*+ and you dont know it.
02-15-2008, 11:33 AM
#12
as for 2 EGTs, you dont need 2. just put 1 in runner #4, and if you want more info on whats going on inside the engine, spend the extra $ on a scanner or wide band o2 . THEN your rocken!!
02-15-2008, 04:10 PM
#14
NORCAL
Engine: T2'd 2.2L
All this has got me wanting to do some testing on egt probe placement in tubular headers. Just afew more months and i'll have the extra moo-lah to start welding a prototype.
As for a scanner or wb02 i'm not holding back on anything with my ride. I'm starting to look into getting a FAST system from forwardmotioninc.com so i'll have everything at my finger tips with my laptop. Just trying to be able to pass CA smog without having to cheat the emissions part of the test and still be able to go "full race" at just the push of a button.
02-15-2008, 06:20 PM
#15
My Ride: 1986 GLHS #065
Engine: 2.2 Aluminum LongRod
1/4: 11.921
Hahahaha, my car with the fast probe in the downpipe about 6in after the turbo used to go to the "U" in the word "exhaust" on the autometer gauge. Hahah, that was like 1800's+ Thank god for JE's. Its usually around 1550 now.
