Old 03-02-2008, 08:34 PM   #1
P0037 Code
My Ride: 2002 Dodge Ram 1500
I am receiving a p0037 Code. I know its the 02 sensor low voltage. Can anyone tell me if its the one before the converter or after the converter. We put a new one ahead of he converter and reset the code but the check engine light came back on while driving down the road. I guess what I'm asking is the low voltage in front of the converter and the high voltage one after the converter?
Jerry
jakj123 is offline
Old 03-08-2008, 01:29 AM   #2
Re: P0037 Code
My Ride: 86 SC, 94 Duster
Engine: 2.2 TI, 3.0L
Read my reply to your other post
Sittn86 is offline
Old 03-08-2008, 07:19 AM   #3
Re: P0037 Code
You need a scanner to tell you which O2 is creating the fault.
Depending on how many O2S there are it will read O2 1/1, O2 2/1, O2 1/2 or O2 2/2.
O2 #1 is in front of the cat with 1/1 being on the side of #1 cylinder.
O2 # 2 is the Cat efficency O2 and is listed the same with O2 1/2 being on the side of #1 cylinder.
Old 03-08-2008, 09:25 AM   #4
Re: P0037 Code
My Ride: 85 GLHT, 87 ShelbyZ
You don't need a scanner. Google OBD2 codes. You know bank 1 is cylinder #1. Just got done fixing a P0038 code on my g/f's jeep. Found a list somewhere saying it's Bank 1 cylinder 2 but I didn't know which one was bank 1. I went and asked the service dept and they told me which one it was. Easy enough. But if i had crawled under there I would of seen the wires had somehow come out of the clip and melted clean through on the exahust pipe. Anyway a new Bosch O2 was a whopping $30 at Napa. 10 minutes later and we were a rocking. I bet a P0037 is bank 1 sensor 1.
GLHNSLHT2 is offline
Old 03-08-2008, 05:13 PM   #5
Re: P0037 Code
Here are the diagnostics for P0037.
This is for a gas engine as you did not specify.
I just repaired this condition on a 2008 Wrangler 3 weeks ago, it was a faulty PCM, hope yours is only a HO2S.
Old 03-08-2008, 07:03 PM   #6
Re: P0037 Code
yep drivers side downstream O2. check the wiring, replace the sensor. I would assume it's the same price/pn as on my g/f's 04 libby.
Literatura fantástica | Personal Car Finance | Debt Help | Cheap Electricity | Advertising
Page generated in 0.44820 seconds with 13 queries
