05-04-2008, 01:27 AM
#16
Re: 3" Exhaust Question
My Ride: 85 GLHT, 87 ShelbyZ
I bought a daytona kit for my C-Jet (New Yorker) from TU figuring they should be exactly the same around the gas tank and over the axle which from the 2 ShelbyZ's I have sitting next to it look to be that way. Well I had to shorted the S pipe around the gas tank to try and get it to sit as close as possible, then had to cut the next piece in half, add 8" of pipe and it's still not perfect. Close but not exactly the way I want. I think I'm gonna take it off, cut it again and clock the last bend some more and weld it back on. But even though it's been a hassle I'd still buy it again probably. At least it get's you in the ball park with mandrel bends.
Right now it's an orignal Rick D 3" d'pipe, to 40" of napa 3" pipe, to the TU with an 1 1/2 taken out of the S pipe, to the next TU pipe with 8" added there(glad i bought 48" of pipe at NAPA) to the next piece of TU pipe to get you to the muffler(which I don't have) And then a 29" piece that Chris threw in the box(Thanks!) to get it out the back.
Funny thing is, it's quieter than my buddies Kcar wagon and he has an exhaust shop crush bent 3" system WITH a muffler!!!
The pipe TU uses is a thinner gauge than the NAPA pipe which makes it lighter. Very nice tubing.
Either TU's or FWD's is a good setup from the cat back. But be prepared to cut and hack it no matter who's you purchase. Just the nature of the beast. 3" is TIGHT in there. But once it's on mmmmmmmmmmm. That new yorker get's up and scoots now. Seat of the pants says 3 tenths off the 1/4 mile with just the exhaust upgrade and I had 2.5" straight pipe all the way back to the 2nd bend before the axle where it connected into the factory system and ran 14.3 on that setup at 15psi. So I think it's a high 13 second car now. Running 11.5-12.0 at WOT on the wideband with +20% FFV injectors on a stock 88 T2 calibration. I need to adjust it a bit cause they like to idle at 10:1 when cold and ignoring O2 output still. I also need to have the wideband run the car cause that factory O2 sensor is a POS making the car run 14.3-14.5 at cruise. Sorry, rambling.
