06-21-2008, 08:43 AM
No Boost Creep?
My Ride: '89 LeBaron
Engine: 2.5 T1
Finally did the first major mod to my '89 LeBaron 2.5 T1. Rebuilt the motor last fall and installed a G Valve set to 12 PSI, and have put about 3000 miles on it since then.
Decided that the first upgrade needed to be bigger exhaust, so ordered a
2 1/2 inch catback system. It sat unopened in the garage for a couple months, when I finally opened the box, I discovered that it was 3 inch pipe.
Worried me a bit, I've read on here that with my little Mitsu, boost creep is about a 50/50 chance with 2 1/2" and nearly certain with 3".
Figured what the hell, if it creeps I'd port the wastegate some. So I bought a 3" hi-flow cat to go with the 3" pipe. No muffler yet, didn't know what would fit until the pipes were installed.
Installed the system two days ago. Only took three hours - my buddy recently installed a lift in his garage (I'm jealous) so the work went quick and easy. Mighty tight over the axle, but didn't have to shift the gas tank like some have done. Test drove the car yesterday and did some WOT runs to near redline in second gear. No creep at all ?? The only difference I see is that instead of the rock solid 12 PSI that it's been running, now it's 13 PSI rock solid.
There must be a horseshoe hidden in my trunk somewhere, I'm just amazed and pleased that there's no creep problem. Ordered a magnaflow oval muffler this morning. Although the car sounds awesome at full throttle, I just don't need the ticket that I'd inevitably get, and I also want to keep this car in "stealth" mode for future fun with ricers and mighty mustangs.
Randy
