10-04-2008, 12:48 PM
Re: dual exhaust with cutout?
NORCAL
My Ride: 86DodgeLancerPacific
Engine: T2'd 2.2L
I'm guessing that you shouldn't gain much back pressure from spliting your pipes...and i'd put my cutout as close ta the downpipe as possible. Though i wouldn't have it operated by a WOT switch, i'd have it hand switch operated.
If you do go 2.25in lemme know....i got a 2.25 magnaflow muffler with about 5k on it that i wouldn't mind getn rid of. As well as a 2.25 high flow 0bd2 cat..
'86 Lan. Pac. 2.2LT2d CB w/ FWDp Eagel Rods, .040 venolias, ARP studs everywhere, ported exhaust mani, g-valved, egt & boost gauge pillar pod, custom cal, TU 4-puck yellow pp, a555 w/ quafie lsd, alum. flywheel, Full 3in mandrel bent exhaust w/ TU 3in SV & OBD2 h/f cat, Magnaflow straight through muffler, Turbonetics t3/t4 .63 ar stage 2 wheel w/ custom weld job to clear head, cummins fmic, KONI adj. coilovers, adj. rear koni shocks, SLH ''11inch. vented rear rotor conversion
