12-11-2008, 05:43 PM
Re: What size exhaust?
My Ride: 1989 lebaron gtc
Engine: 2.2turbo t2 shelby
I just wanted to make mention because your new to the forum ,Those swing valve bolts can be a (PAIN) , I normally take a small torch and heat up the housing a little before i get started (no broken bolts that way),dont go over board on the heat but it helps , on my lebaron i used the 2.25 sv on the garret went to a 2.5 pipe through a high flow cat for a 360cub engine straight from there, sounded great ,cruses nice, will put u to sleep though, u can here the turbo spool in the pipe , The only complaint i have is even with the high flow cat and straight before the cat i would get 2-3psi of back pressure under full boost14psi , but i'm running a g-head with port work, and gasket matched exhaust mani ,
