Old 09-22-2003, 05:53 PM   #1
exhaust matchup to swingvalve
dieubershreck
my question is will the 2.5 downpipe mount up to the swingvalve on my 87 t1 shadow or will i have to buy a 2.5 swingvalve also?
shawn
Old 09-24-2003, 12:02 AM   #2
Yes, just die grind the bolt holes a bit.
JDIZZ is offline
Old 09-24-2003, 10:27 PM   #3
dieubershreck
i dont know what you mean by die grinding the bolt holes, if you could describe it to me in more detail i could probably do it at school. thanks.
shawn
Old 10-06-2003, 06:17 PM   #4
The two mounting holes are a little further apart on the 89.
JDIZZ is offline
Old 10-06-2003, 06:24 PM   #5
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
The mounting holes in question are on the downpipe donut flange. The downpipe is matched to the turbo exhaust outlet, so a mismatch of downpipe and turbo outlet size will mean the bolt holes on the flange and turbo outlet won't line up.
I used a Dremel and carbide cutter bit to grind the bolt holes in the flange inward, so that they matched up with the smaller turbo outlet. The flange itself it stainless steel, so it's a real pain to grind..
Be sure to use eye and hand protection. I had shards imbedded in my forearms when I was done.
iTurbo is offline
Credit Cards UK | Mortgages | Guitar Lessons | Mortgage Calculator | Problem Mortgage
Page generated in 0.48392 seconds with 13 queries
