Old 09-22-2003, 06:37 PM   #1
The Cat Is Commin Off! need sizes tho...
My Ride: 88 Turbo Lebaron
im almost 1000% sure thats what is killin me up top. so its commin off tonight. i just need to know how big the inlet on the cat is to get a "test pipe" for it. i know the outlet it 1.75. thanks guys.
OneFastBaron is offline
Old 09-22-2003, 06:38 PM   #2
inlet is 2.25" and the outlet is 2.25", it doesn't go down to 1 7/8" till over the axle
89daytonaTII is offline
Old 09-22-2003, 07:08 PM   #3
thanks alot man! i dont know why tho. but according to the discount auto store computer it says 1.75 at the end of the cat
Old 09-22-2003, 07:14 PM   #4
by anychance will a 2.5in pipe work? no one seems to carry 2.25 and i cant get thru to autozone *** i hate autozone
Old 09-22-2003, 07:33 PM   #5
if you have 2.25-2.5 flanges on either sides of the 2.5 pipe then it will work, but if not there's too big of a size difference
Old 09-23-2003, 01:54 PM   #6
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
How about if you just "hollow out" the cat. I have seen people take pipes to smash the stuff out.
dyno sheet
fmic install:
crazymadbastard is offline
Old 09-23-2003, 03:06 PM   #7
Inlet on the cat is 2.5". Outlet is 2.25".
I used a 2.5" pipe (18") from Autozone with a swaged end on one side. This end I clamped to the downpipe. On the other side, I believe I used a 2.5" -> 2.25" adapter, clamping the adapter on the outside of the stock exhaust pipe.
This was some years ago, so I'm a little iffy in the adapter size. Worked great, though.
lametec is offline
Old 09-23-2003, 06:16 PM   #8
i think they changed it to 2.25in. inlet. for 88. i know the outlet is 2.25in. of course no one carry's 2.25in pipes
heh i found out another reason why my car was really slow up top... i blew some vac lines off LOL zip ties own me!!!! now to check the cam and ignition timing
Old 09-23-2003, 06:32 PM   #9
one last question! is the pipe gonna be dragin when i cut it? i wanna run open downpipe for a while. is the rest of the stock exhaust gonna just dangle.... any way i can string it up ghetto stylin?
Old 09-23-2003, 06:38 PM   #10
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (22)
If you gonna do that just remove the whole system past the DP.
dyno sheet
fmic install:
Old 09-23-2003, 07:02 PM   #11
yes the DP will hang too low once it's cut off before the cat and nothing is hooke dup to it. I used and still am using some 16guage wire (solid not coiled) and have strung it up from the heat shield "bolts" the DP is light enough that it won't be a problem.
Old 09-23-2003, 08:52 PM   #12
dont you mean behind the downpipe? i was thinking of just doing the same as you said... get some wire and string it up... coat hanger maybe
and crazymadbastard i said running an open down pipe for a while. not for very long.
Old 09-23-2003, 09:06 PM   #13
behind the DP, before the cat. same place
Old 09-24-2003, 08:59 AM   #14
Nope. Inlet was always 2.5". My Lancer which I did this to was an '88.
Grab a 2.5" pipe like I said.
lametec is offline
Old 09-24-2003, 12:39 PM   #15
so the 2.25" DP flanges to 2.5" for the cat. hmm learn something new everyday. I use to have an 88 but never modified it one bit so i didn't notice.
Actress | The eBay Song | Guitar Lessons | Debt Consolidation | Credit Cards
Page generated in 0.42271 seconds with 13 queries
