10-03-2003, 10:11 PM
3" exhaust + mitsu turbo = overboost?
My Ride: 89 Caravan
I am running my van at 12PSI via a dawes boost controller and mitsu turbo. I am going to upgrade the exhaust to a 3" with ultraflow muffler. I am wondering if everytime I get into it will I hit over boost?
I think I heard awhile back that a 3" on a mitsu will hit overboost. If this is true can I just back off on the boost controller to fix this?
Thanks,
Jeff
10-03-2003, 10:39 PM
My Ride: 89 Caravan
**** that really sucks, I only want to buy a exhaust one time.
10-03-2003, 11:21 PM
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
Either way, a 2.5 T1 with a Mitsu turbo 2.5" or 3" exhaust will have boost creep issues. I route full manifold pressure to the wastegate can on my Mitsu turbo 2.5 T1 Shadow and it will hit 5 psi instantly, and then creep all the way to cut out. I would upgrade the turbo first. If you do open the exhaust first, you may have to control the boost as described above to avoid cutout.
10-04-2003, 03:58 AM
My Ride: 99 Cummins
Engine: 5.9
If you have it graingered between the turbo nipple on the air outlet and the wastegate it shouldnt.. i have a mitsu with 3" starting about 4" from the turbo back, hollowed cat and dynomax strait thru...
dont grainger it between the intake and the wastgate or you will have that problem.. i had fluctuations and creep quite often off the intake..
10-04-2003, 07:18 AM
My Ride: 89 Caravan
Thats how I have it set up right now. I wanted to upgrade the exhaust as its the 1st thing to do but this issue came up.
Thanks,
Jeff
10-06-2003, 04:50 PM
#15
I route full pressure to the wastegate can. It still creeps of course, but at least I can avoid the overboost cutout. The best way to cure it is get a TII turbocharger.
