01-11-2004, 11:05 AM
#20
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
For cast iron, I use carbide cutters with very fine teeth. I have ball shaped cutters, some with straight sides and a rounded tip, and one that is kind of teardrop shaped but on both sides. Looks like an oval more or less.
They each have their uses for certain parts of the ports.
My first porting job was on a /6 head with nothing other than a single 1/8" shank cutter and rounded tip. The CUTTING section was also 1/8" diameter! Needless to say, it took a LONG time! But the /6 picked up 15 HP when I was done with no other changes.
For aluminum, I have one carbide cutter that is large (1/4" diameter) at the base, and has a rounded taper to the tip. It is very coarse, with only 6 teeth. It makes the aluminum chips fly! While cutting aluminum, I stop about every minute or 2 and clean out the pieces from the teeth and dip the cutter in ATF, which helps a lot.
DO NOT use fine tooth carbide cutters on aluminum! They will clog up in about 10 seconds and then it's ruined unless you want to spend a 1/2 hour digging the aluminum out of it.
The last time I ported an iron head, I borrowed someone's 1/4" air grinder and a box of larger size carbide cutters. That thing carved the iron out pretty quickly! A huge time saver. But nothing can beat a Dremel for the final finishing and shaping.
