Old 01-08-2004, 05:18 AM   #16
My Ride: 87 GLHS
Engine: 2.2 8Valve
Originally posted by glhs636
Looks great "thumbs up
One question, is that going to clear the starter?
It's designed to clear the starter and power steering pump. And also designed so that the swingvalve remains at the stock or near stock location so that downpipe mods won't have to be made. This header along with some other things is just one of the parts in the works in the quest to make a 2.2 8V make power beyond 6000rpm.
Brian Putman is offline
Old 01-08-2004, 10:44 AM   #17
Originally posted by AJMcCurdy
Well I'm willing to let my car be another "test subject"......
Hahahahaha, I second, third that motion "thumbs up
Old 01-08-2004, 11:00 AM   #18
My Ride: 1987 shelby csx
Engine: 2.4 dohc conversion
this header probably wont show significant improvement over a ported stock manifold unless you are real close to making 300 whp. but then again not sure on that yet either. kevin
kedavis is offline
Old 01-08-2004, 11:05 AM   #19
Who cares, I want one, lol
Old 01-08-2004, 04:58 PM   #20
are you only changing the exh manifold?id be curious on how much gain it makes.looks realy nice,good work."thumbs up
silvershelby387 is offline
Old 01-08-2004, 05:13 PM   #21
me too we will find out this spring.
kedavis is offline
Old 01-08-2004, 08:01 PM   #22
I noticed something about your header as well as Alabama mans. Why are you guys cutting the flange between the ports. I could see the thought process of less chance of warping but that takes a bit of the clamping force off of the one side of the port.
I also have a couple things in the works, finally got my own TIG instead of using works so it is easier to do stuff in my free time.
MM Racing is offline
Old 01-09-2004, 07:47 AM   #23
your right about the thought process when put in the oven and brought up to 1800 degrees it wants to warp because the way the flange has to be on our fine intake exhaust same side flanges design.what tig did you get thinking of buying one myself.
kedavis is offline
Old 01-09-2004, 09:50 AM   #24
R.Drake
Looks great kevin. Cant wait to see how it works.
Ryan Forward Motion
Old 01-09-2004, 01:11 PM   #25
I picked up the Lincoln Electric TIG 175 Pro. Havent actully gotten it hooked up yet since I only have 12AWG wire going to the garage and that wont handle the 50A this thing is supposed to draw.
The Miller SynchroWave 180 is about the same thing but a little mor pricy.
Ian
Old 01-09-2004, 08:02 PM   #26
header w/ 3" SV????
does it relocate the turbo or keep it in the stock location? Could you use it with a 3" SV? Ive heard (dont know for a fact) that it is difficult to use Alabamaman's header AND a 3" SV because it relocates the turbo.....anyone know if theres any truth to this??
ZDaytona is offline
Old 01-10-2004, 01:17 AM   #27
turbo stock location thats the idea i have a tu 3 inch swingvalve also.
kedavis is offline
Old 01-10-2004, 01:20 AM   #28
that is a very good tig for the money that wiring issue is easy enough to take care of .we will have to hook up at sdac and pop some tops.kevin
kedavis is offline
Old 01-22-2004, 07:55 PM   #29
header tubing
Hybrid Booster
purevl's Avatar
just out of curiousity, if one were planning to make similar headers, will regualar 16ga header tubing be enough to stand up to the heat of a turbocharged engine, or would you have to use structural tubing or something similar? please forgive my ignorance
purevl is offline
Old 01-22-2004, 09:32 PM   #30
My Ride: 73 roadrunner
Engine: 340 c.i.
Did you have the flanges machined out by a shop or did you mack them your self? I've thought about making an equal lenght 14g stainless header but dont have the equipment to laser cut or fab flanges.
It looks very nice"thumbs up
Joe
Super60Dodge is offline
Mortgage | Mortgage Calculator | Personal Car Finance | Proliant Harddrives | Hotel Las Vegas
Page generated in 0.40322 seconds with 13 queries
