02-01-2004, 11:18 PM
I'm in the same boat as you, just got a 85 charger, and wanting to put a 3" exhaust on. I personally wouldn't worry about getting the "lighter" exhaust, there are other things you can loose weight with rather than exhaust, unless you want to spend the extra money. The "G-Valve" is a grainger valve, which allows the turbo to run more boost. click me <-explains it a little and shows how to make one. If I were you, I'd just buy one, you can get em for about 15-20 bucks. The Air/Fuel guage seems to be an easy install. 3 wires: power, ground and one wire to the o2 sensor. Boost I don't know how hard it is to hook up, but I'll tell you in about a week  . You won't need a boost controller, because a Grainger is a boost controller. Good luck with the new Charger."thumbs up
